Guage cluster problem...HELP :(
I just got done painting my guage cluster bulbs amber, I placed them back in the back of the guage cluster and nothing happened. When I turned on my lights the cluster didn't light up and my climate control cluster didn't light up. Could I have blown a fuse??? Help PLEASE
Risky Business
Re: Guage cluster problem...HELP :( (kKdARIAN)
Did you remember to plug the plugs back into the climate control? I know it sounds stupid but thats what I forgot to do...
I turned the car on and my lights on because it was getting dark anyways. When I turned the lights on the clock on my dash did't dim like it always does.
Re: Guage cluster problem...HELP :( (BauleyCivic)
When I check the fuses do I just check the ones under the dash ( I have an eg)???
Re: Guage cluster problem...HELP :( (jdmjeff)
Also... I touched the back of the guage cluster alot... maby I shorted the cluster out but other than that, that is really all that I done.
Re: (ng)
No, Im positive of that... The one thing that I'm thinking is that when I carried it out to my car I must have gotten the "natural" oil off of my hands on the back of the cluster.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">When I check the fuses do I just check the ones under the dash ( I have an eg)???</TD></TR></TABLE>
Correct....
as stated before, take a flash light and look at each fuse. If that little metalic wire is broken in half, the fuse is dead
Correct....
Re: Guage cluster problem...HELP :( (Ekay)
yes, I bought a kenwood CD player about five months ago. But It has not gave me any problems
I found out that the problem was just a fuse...but when I put the new fuse in (it was the same number) the fuse blew again. I guess one of the wires are showing and touching something else.
check to make sure a (+) wire isnt touching a (-) on the cluster or whatever you took apart, they will keep blowing untiil you fix the short, this happened tome before but it was my radio cuz i was f'in with it
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">yes, I bought a kenwood CD player about five months ago. But It has not gave me any problems</TD></TR></TABLE>
Then I know exactly what the problem is, because the same thing was happening to me. The instrument and climate control lights werent working, and the fuse for them kept blowing. A spare wire left over from the install is making contact with metal in youre dash. You need to take out youre climate control, locate the wire, and tape the hell out of it. Then replace the fuse and it will work.
Edit: It's usually orange. I can go do a write up with pics if need be.
sol-oto
06-17-2018 08:56 AM
