Losing weight
Old Mar 19, 2008 | 11:48 PM
93H22's Avatar
Default Losing weight
just a question on the 93 prelude VTEC...it weighs 2932 curb weight...stripping the rear seats and some interior parts and some stuff out of the trunk...how much weight do you think i will lose? say i run 13.9....stripping it what do you guess i would run? thanks guys
Old Mar 20, 2008 | 12:00 AM
ethereal2pt2's Avatar
Default Re: Losing weight (93H22)
the rear seats on my 98 barely weigh anything and i'm guessing it'll be no different for your 93. a good but not exactly accurate way of gauging 1/4 time w/ weight is for every 100lbs, you shave a tenth of a second off your 1/4. search for the weight reduction thread.
Old Mar 20, 2008 | 05:47 AM
subydoored's Avatar
Default Re: Losing weight (ethereal2pt2)
buy taking the sunroof out and putting a cap on will save you 43 lbs. also if you remove the tar off car thats inside will save 15 lbs. replace the seats can save you a ton of weight also carbon fiber trunk and hood.
Modified by subydoored at 8:13 PM 3/20/2008
Old Mar 20, 2008 | 09:56 AM
JDM R Cooker's Avatar
Here are some good info. If ur car weight almost the same as our, then shoudnt be a huge diff. http://www.importmodifications....html
Old Mar 20, 2008 | 10:02 AM
snobordboy's Avatar
Moderator
I can say that removing cruise and a/c, running a civic radiator, and a carbon hood, no spare tire etc, my 93 weighs 2905 with my 235 lbs in it. So the car weighs roughly 2670.
Old Mar 20, 2008 | 10:21 AM
subydoored's Avatar
Default Re: (snobordboi)
thats a decent amount of wieght off the car. i have a magazine article some where that a japan tuner shop took his s2k and an integra and stiff the chasis and swiss cheesed the inner planels and got both cars about 500lbs lighter. now if i can find the dam thing
Old Mar 20, 2008 | 11:05 AM
Hawkze_2.3's Avatar
Default Re: Losing weight (subydoored)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subydoored &raquo;</TD></TR><TR><TD CLASS="quote">buy taking the sunroof out and putting a cap on will save you 70 lbs. also if you remove the tar off car thats inside will save 15 lbs. replace the seats can save you a ton of weight also carbon fiber trunk and hood.</TD></TR></TABLE>
I don't know what gen you're talking about, but on a 4th gen you loose about 43 lbs from a sunroof plug, not 70.
Old Mar 20, 2008 | 11:13 AM
subydoored's Avatar
Default Re: Losing weight (Hawkze_2.3)
ahh my mistake
austrian type-R
Acura NSX
Jan 15, 2004 09:23 AM
mrnicolas
Jan 18, 2003 08:39 PM
CRXSleeper
Aug 25, 2002 12:37 AM
EleanoR
Jul 5, 2001 02:05 PM
