Suspension & Brakes Theory, alignment, spring rates....
Question on rear sway bar end links??
Old Mar 19, 2008 | 11:30 PM
VTECth1s's Avatar
Default Question on rear sway bar end links??
I plan to go with the 22mm ctr rear sway bar with asr subframe and omnipower lcas. Which aftermarket endlinks would fit correctly? I had in mind, blox endlinks? but plenty people have problems with them. Help or tips would be appreciated.
Old Mar 20, 2008 | 06:31 AM
meb58's Avatar
Default Re: Question on rear sway bar end links?? (VTECth1s)
We tried adapting function 7 endlinks to an old GC swaybar...these endlinks are not impressive either. The rod ends are very small and therefore do not articulate far enough to meet the range of suspension stroke required. High misaligned rod ends would work better and we can have those custom made but at a cost considerably higher than purchasing a nice new bar.
We're are moving back to stock endlinks for this application...I have not seen endlinks offered for Honda/Acura that I personally like...yet.
Unfortunately, Powergrid make beatiful endlinks for many other applications. I used these on a track Mini and they are simply awsome; full ball joint type - lots of articulation (53 degrees worth) endlinks, adjustable, buttery smooth, but a wee bit heavy.
how much do you want to spend? The custom endlinks were up to about $300.00 each...made by a local company who compete with Aurora.
Old Mar 20, 2008 | 02:07 PM
VTECth1s's Avatar
Default Re: Question on rear sway bar end links?? (meb58)
Hmm not sure. I just hope to not be dishing out $300 for endlinks. But I'd be willing to pay around $50-150 for endlinks.
sk8shorty012
Suspension & Brakes
Oct 22, 2010 01:57 PM
crexer
Jul 7, 2009 06:06 PM
ekinshuya
May 31, 2009 07:36 AM
thegreat0ne
Aug 24, 2007 09:29 PM
tthomass
Suspension & Brakes
14
Apr 11, 2005 01:00 AM
