need some help with installing an itr IM
Old Mar 19, 2008 | 10:03 PM
hectic57's Avatar
Default need some help with installing an itr IM
i've just installed an itr manifold on to my b16 and now i'm in the process of putting the plug for the air temp sensor and the fuel pressure regulator is in the way...did any one encounter this problem with their itr intake manifold install on to a b16a?if so can you please help me?
Old Mar 20, 2008 | 11:33 AM
hectic57's Avatar
Default Re: need some help with installing an itr IM (hectic57)
BUMP....can anyone help me out?
Old Mar 20, 2008 | 11:57 AM
crazyguy's Avatar
i installed itr intake manifold on my jdm sir2 b16a engine. swap is pretty straight forward.just a few nuts to loose .but it is time consuming cause u have so little room to work with. this swap took me about 90 mins with hand tools and a little bit of power tools.ITR intake manifold bolts right on and i reuse all the sensors , fuel injectors and fuel rail and eliminate/capped a port, i bought a new intake manifold gasket. IACV on my jdm b16a intake manifold wont bolt on to ITR intake manifold.so i got one from a obd2 98 civic dx, or u can get one from 96 and up integra.cause 94 and 95 has wider bolt pattern. i also use brand new p73 ITR throttle cable and p73 ITR throttle cable bracket. but u can reuse your b16a throttle cable and bracket.
i had it bored to 68mm and so it will work with my new skunk2 68mm TB (oem b16a TB is 60mm)
here are pics that i took.
the bracket underneath intake manifold is pain in the butt to remove ,so i didnt reinstall it back on. pm me if u have any more question.
took off p30 intake manifold, power sanding old gasket off and make it smooth for the new gasket
done..tah dah
Modified by crazyguy at 1:21 PM 3/20/2008
luvs2h8
Jul 12, 2012 07:15 AM
SiR Inspired ED7
Jul 27, 2007 03:43 PM
dfoxengr
Feb 12, 2004 09:00 AM
