coolant leaking bad need HELP
ok I just got this 93 integra and it leaks coolant from the driverside. Right next by the alternater by the pulleys too. I found out which part its leaking but dont know what went there before. There's two 10 or 12 mm bolts side by side next to eachother and a hole on the left side of the two bolts. And that hole is the problem to leaking. Is it supposed to be a seal or tube or i dont know. Need help asap please
wish I could I'm using the iPhone rite now. But yeah went to local mechanic shop and they put my car on the lift to see which spot was leaking from. They say its water pump. Is there any tubing or bolt that would seal the water pump. So i could make sure its water pump leaks out of a circle hole next to 2 bolts Damn I need to get pics for better discription. I own all these cars but never got to any of these situation. Never worked on any internals. Just basic bolt one and lowering
when a water pump goes bad most of them have a little pin hole that will start leaking right around the pully. inwhich case would be best for you if you spent the 50 bucks and got a new one. but if its leaking arounf the outside just take it off and re seal it.
Yeah i never changed water pump to do that i would have to go through timing. But i think imma try. So just want to know besides it leaking. Does it cause radiator to start bubbling i hope its just water pump. Everything else is ok. Drives smooth. I think no smoke except on radiator cap when heats up
WingedMan
Apr 26, 2021 05:03 PM
del_parker
May 14, 2003 04:58 PM
