vtec question
Old Mar 19, 2008 | 07:50 PM
v!taminb16's Avatar
Default vtec question
does anybody know why my car at times when i crack vtec it has a little stutter it's nothing major but i can feel little tugs in the car when i crack vtec is this normal or does nobody know what im talking about it's hard to explain
Old Mar 19, 2008 | 07:53 PM
nicks-eg6's Avatar
Default Re: vtec question (v!taminb16)
crack vtec????? what kind of CRACK head says that?
ok on to your problem. could be your air/fuel mixture. when was the last time you did a tune up?
Old Mar 19, 2008 | 07:54 PM
nicks-eg6's Avatar
o and i like police. they protect me. lol
Old Mar 19, 2008 | 07:56 PM
v!taminb16's Avatar
Default Re: vtec question (nicks-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">crack vtec????? what kind of CRACK head says that?</TD></TR></TABLE>
i didnt know crack head's know anything about vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">ok on to your problem. could be your air/fuel mixture. when was the last time you did a tune up?</TD></TR></TABLE>
i havent gotten a tune up in a while but i did notice that it didnt do that before i got my car tuned is this sonthing that i should worry anbout or could it be normal ??
Old Mar 19, 2008 | 07:58 PM
Midori Green's Avatar
yea crack as in mmmmmmmmbaaaaaaaaaaaa!!!!!!!!!!!!! dont know bout you but vtak is like crack i mean its got me hooked so thats what i call it... damn i need re-hab
Old Mar 19, 2008 | 08:01 PM
v!taminb16's Avatar
Default Re: vtec question (Midori Green)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">yea crack as in mmmmmmmmbaaaaaaaaaaaa!!!!!!!!!!!!! dont know bout you but vtak is like crack i mean its got me hooked so thats what i call it... damn i need re-hab</TD></TR></TABLE>
well i dont know about all that
is anybody going to help me figure out my problem or are you guy's just going to talk about crack
Old Mar 19, 2008 | 08:05 PM
nicks-eg6's Avatar
we'll when you had it tuned you should have done a tune before just to make sure everything is up to snuff. what engine management are you running?
Old Mar 19, 2008 | 08:08 PM
v!taminb16's Avatar
it's just a simple street tune.....im running hondata rigged to chrome
Old Mar 19, 2008 | 08:11 PM
nicks-eg6's Avatar
we'll have you cleaned your vtec screen? checked your plugs? oil?
Old Mar 19, 2008 | 08:14 PM
v!taminb16's Avatar
well my plugs are new just changed my oil my car runs perfect but
[QUOTE=nicks-eg6]we'll have you cleaned your vtec screen/QUOTE]
interesting how would i do that....
Old Mar 19, 2008 | 08:17 PM
nicks-eg6's Avatar
you know where your vtec solenoid is... unplug the wires. unscrew the three bolts holding it down. pull it off. then you will see the screen sitting in a little puddle of oil. pop it out and clean it off. then just reverse the process and try and see if that didnt help.
what performance parts do you have on your car?
Old Mar 19, 2008 | 08:25 PM
v!taminb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">you know where your vtec solenoid is... unplug the wires. unscrew the three bolts holding it down. pull it off. then you will see the screen sitting in a little puddle of oil. pop it out and clean it off. then just reverse the process and try and see if that didnt help.
what performance parts do you have on your car?</TD></TR></TABLE>
alrite ill do that tomorow just wipe it off or clean it off with somthing???
just bolt ons
Old Mar 19, 2008 | 08:33 PM
nicks-eg6's Avatar
yeah. just use a clean rag or towel.
Old Mar 19, 2008 | 08:36 PM
v!taminb16's Avatar
alrite....is there anything else i can do
Old Mar 19, 2008 | 08:40 PM
nicks-eg6's Avatar
look into to your fuel/ air mix to make sure your not running to lean or rich.
Old Mar 19, 2008 | 08:48 PM
DA_9's Avatar
Here I got a couple of things for you buddy.
Checking if you are running rich or lean the Honda way:
Take out the spark plugs, clean them off real good, put them back in.
Take your car out, put it in third gear, go from 2000 rpm to redline.
Immediatly shut off your car and look at each of the spark plugs.
Dark resude is running rich
Light resude is running lean
Clean is the shizznet.
Change your spark plug wires, your spark plugs, and cap and rotor to dizzy aka tune up. Check your timing.
Any CELs?
Take your vtec solenoid, ground the vtec pressure switch. Then retune or rechip it to the same map but dis engage the vtec pressure switch- that fixed my problem which was the same.
Fuel filter, fuel pump, injectors....do fuel system cleaning if all else fails. Go to your local jiffy lube ask for a cash deal late at night, most likely they will say yes and charge u like 40 bucks cash to do a cleaning instead of 100. TRUST ME i know this works.
PS if u changed ur intake many after the tune, that is the problem ur A/F mixture is off.
Honestly, I think it will be fuel filter, or spark plugs. but check it all. Do this all and let me know what is up and I will have u try more if that fails. Much luck!!!
Old Mar 19, 2008 | 08:54 PM
v!taminb16's Avatar
Default Re: vtec question (DA_9)
well in know im running rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 &raquo;</TD></TR><TR><TD CLASS="quote">Fuel filter, fuel pump, injectors....do fuel system cleaning if all else fails. Go to your local jiffy lube ask for a cash deal late at night, most likely they will say yes and charge u like 40 bucks cash to do a cleaning instead of 100. TRUST ME i know this works.
Honestly, I think it will be fuel filter, or spark plugs. but check it all. Do this all and let me know what is up and I will have u try more if that fails. Much luck!!!</TD></TR></TABLE>
the fuel filter is new and so are the spark plugs but ill change them and see if it still happens....so you think i should claen out my fuel system
Old Mar 19, 2008 | 08:58 PM
DA_9's Avatar
Yeah if ur running rich alot of shyt will build up in there, do this, clean it and tune it within 24 hours. that should fix ur problem and give u more power.
Old Mar 19, 2008 | 09:01 PM
v!taminb16's Avatar
so clean out my vtec solenoid and my fuel system
Old Mar 19, 2008 | 09:05 PM
DA_9's Avatar
And re-tune immediatly, then try the rest.
Old Mar 19, 2008 | 09:08 PM
nicks-eg6's Avatar
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 &raquo;</TD></TR><TR><TD CLASS="quote">And re-tune immediatly, then try the rest.</TD></TR></TABLE>thats what im beginning to think that it is in your tune
Old Mar 19, 2008 | 09:11 PM
v!taminb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">.thats what im beginning to think that it is in your tune</TD></TR></TABLE>
but i sont think it's that because it does this every so often im hoping thats its nothing major im going to try to run a stock em1 ecu ans see how it works
Old Mar 19, 2008 | 09:16 PM
nicks-eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v!taminb16 &raquo;</TD></TR><TR><TD CLASS="quote">
but i sont think it's that because it does this every so often im hoping thats its nothing major im going to try to run a stock em1 ecu ans see how it works </TD></TR></TABLE>
ok. what motor are you running now?
Old Mar 19, 2008 | 09:18 PM
id3379's Avatar
yea, try that stock ecu, if that works then for sure its your tunned ecu, other wise its engine related.
Old Mar 19, 2008 | 09:20 PM
DA_9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> ok. what motor are you running now?</TD></TR></TABLE>
Dont matter. You are running rich, ur tune sux ****. Point and fact not gonna bs u about it. Your tune is ur A/F mixture, the A/F mixture is off, your tune is ****. Clean the fuel system before u retune or u may end up wit the same problem. Do this u will not regret it.
