DPFI==>MPFI parts list, what do you think of this?
I'm in the process of converting my '88 wagovan from DPFI--->MPFI.
The old stock engine died, so the previous owner replaced it w/ a JDM D15...but chose to retain the DPFI. He didn't have any MPFI parts to give me (the shop that did the swap bought the engine and kept all the MPFI parts---which they already sold off).
So far, the parts I have for the MPFI swap:
--D16y8 intake mani w/ TB, FR, FI, and sensors
--DC Sports 4-1 header
--New D16z6 dizzy
A buddy here in NC is helping me w/ the swap, and he's got a P08? (JDM ECU that goes w/ the D15) that we'll be using, along w/ a single wire 02 sensor set-up...(so no 4-wire 02 or P28 ECU needed).
As I'm sure most of you know, the D15 is a SOHC VTEC engine rated at ~130hp (but with my current DPFI set-up, w/ VTEC not hooked up, it's only about 100hp or so ).
I'm pretty sure I still need:
--SI throttle cable (a6)
--SI wire harness (or better yet, OBD0--->OBD1 conversion harness w/ VTEC).
I saw this on egay and wasn't sure if it's the one I need or not:
http://cgi.ebay.com/ebaymotors...ZWDVW
1) Is this the correct wire harness for what I need?
2) ANY other parts I'll need?
I just want to make sure I have absolutely everything ready when we do the swap.
thanks in advance!
bryman
Modified by bryman10 at 4:21 AM 3/20/2008
--New D16z6 dizzy
thanks in advance!
bryman
that is the correct jumper harness...but buy it here instead http://www.rymire.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f-it3 »</TD></TR><TR><TD CLASS="quote">that is the correct jumper harness...but buy it here instead http://www.rywire.com</TD></TR></TABLE>
corrected.
corrected.
Thanks for the head's up on rywire....just ordered it from them.
John (BluecrxNC): Thanks again for helping me w/ this...you're awesome dude!
I just got the D16z6 dizzy, so along w/ the DC header, D16y8 complete manifold, SI throttle cable (that's on the way) and this conversion harness, I think we'll be good to go, right?
bryman<-----almost has all parts now
Check me out here ---> http://www.hondamarketplace.co...28254 for mpfi harness conversions
Modified by monotech at 1:39 AM 3/24/2008
VeilSide_Mas
Feb 10, 2006 08:45 AM
