1st gen CRX si D16A1 turbo *having SMOKE PROBLEMS!!!* ~motor rebuilt~
Old Mar 19, 2008 | 04:48 PM
h22prelude99's Avatar
Default 1st gen CRX si D16A1 turbo *having SMOKE PROBLEMS!!!* ~motor rebuilt~
ok i started a home made project on a 86 crx not too long ago,
but the point is that after driving around for like 10 mins my car starts smoking alot at the stop lights unless if i have it reved up a lil higher. and once i take off it stops smoking and continues on normal.
and the motor is rebuilt with turbo pistons
its a D16A1 DOHC from a 89 integra
any good guesses????
Old Mar 19, 2008 | 05:16 PM
moores55's Avatar
Default Re: 1st gen CRX si D16A1 turbo *having SMOKE PROBLEMS!!!* ~motor rebuilt~ (h22prelude99)
maybe your turbo seals are shot.
Old Mar 19, 2008 | 07:20 PM
stockb18c's Avatar
or your valve seals
Old Mar 19, 2008 | 07:57 PM
redzcstandardhatch's Avatar
something different
Default Re: (stockb18c)
do you have a restrictor in the turbo oil feed? if not, check out one from ATP turbo , or many other places.
Old Mar 20, 2008 | 02:46 PM
quicksilver1689's Avatar
i ♥ snails
turbo seals are a possibility, but you said it only does it at a stop, when its idling. Oil pressure increases as the motor increases rpm's, so your smoking problem would most likely get alot worse when you accelerate. you have alot of vacuum at idle, maybe your pulling oil through some shot valve seals and burning it up in the chamber.
Old Mar 21, 2008 | 04:13 PM
Default Re: (quicksilver1689)
cant be valve seals becouse the motor is rebuilt like i said at first. and for the restrictor, it has one already. and right now its gotten worse to the point where it smoke most of the time now. but i did unplug the oil feed line and the smoking stoped, so for sure it has to do with the turbo.
so probably turbo seal??? cuz the turbo is used
or any other theories??
Old Mar 21, 2008 | 04:15 PM
Default Re: (h22prelude99)
oh yea and also, its water cooled? does that have to do anything with it? should i connect the water line?
Old Mar 21, 2008 | 09:11 PM
93CX's Avatar
Turbo is shot.. replace with known working unit.
Old Mar 22, 2008 | 09:39 AM
mike93eh2's Avatar
that feed line is HUGE!!! a turbo does not need that much oil. get a -3 line and a restrictor fitting.
Old Mar 22, 2008 | 09:46 AM
EASY101's Avatar
* B A N N E D *
wheres your intercooler man?
Old Mar 22, 2008 | 04:13 PM
92civicfreak's Avatar
thats what i'm wondering
or he's just going to wrap that pipe with dry ice
Old Mar 22, 2008 | 11:10 PM
Default Re: (92civicfreak)
oh the intercooler wasnt on at the time for that picture, that was before i blew the motor and had to rebuild it. but it does have one, just aint that big though
so then... i need and even smaller restrictor than what i already have??
my oil press is 20 idle and 40 full throttle if thats any help?
Old Mar 22, 2008 | 11:24 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22prelude99 &raquo;</TD></TR><TR><TD CLASS="quote">
my oil press is 20 idle and 40 full throttle if thats any help?</TD></TR></TABLE>
thats pretty low....
you have a restrictor now? what size is it?
Old Mar 23, 2008 | 05:33 AM
something different
Default Re: (mike93eh2)
is that pressure at the turbo, or pre-restrictor.
the feed line will work, if you've got a restictor, its not big deal
Old Apr 3, 2008 | 10:55 PM
Default Re: (redzcstandardhatch)
well just ordered the rebuild kit for the turbo so hopefully ill b good.
doesnt smoke with out it so ill make sure i update yall once its back in.
thx 4 the advise 2 every1 who spend there time throwing in a guess
hondaluver12
Apr 18, 2009 08:05 AM
luv2boost
Jul 6, 2007 05:01 AM
djnikko
Aug 14, 2003 05:38 AM
B18PoweredCivic
Apr 25, 2003 07:40 PM
