Anything to keep the balljoint from spinning?
you just need to put some weight on the spindle if you want the ball joint to stop spinning. cause if you put vice grips on the boot you will rip it up and it will be point less
the problem is the castlenut.
buy a new castle nut or rethread the old nut. either 10x1.25 or 12x1.25mm, tie rod end or lower balljoint respectively.
Fo-Do Fanatic
10
May 15, 2010 04:02 AM
jdmwannabee
Sep 13, 2009 06:34 PM
Fuster_Cluck
12
Apr 9, 2003 06:06 PM
