Need help Fast!!!
Old Feb 25, 2004 | 03:14 PM
f@sth@tch89's Avatar
Default Need help Fast!!!
Here is my thread from another forum...need more advice. thanx.
https://honda-tech.com/zerothread?id=777840
Old Feb 25, 2004 | 10:45 PM
Spartanic's Avatar
Default Re: Need help Fast!!! (fasthatch89)
Press on the studd with your hand while you tighten the nut. The pressure will force the stuf against the ball joint causing it not to turn.
Old Feb 25, 2004 | 11:06 PM
MrParks's Avatar
i think basicly you counter threaded your ball joint if you dont think you did , then use an impact to do it ,if you dont have access to one then do one of the following :1 buy a new one 2: take a hammer smack it on the top of the ball joint also make sure its free from any oils or dirt this will also make the ball joint spin, then use a 14mm nylon threded nut or a new ball joint nut and ratchet as fast as you can thats my advice to you.good luck
WhiteOnRice
Aug 18, 2024 11:11 AM
jdmwannabee
Sep 13, 2009 06:34 PM
sky9
12
Jan 8, 2008 01:39 PM
azian21485
May 2, 2005 05:48 PM
f@sth@tch89
Mar 1, 2004 06:04 AM
