T bracket?
Old Mar 19, 2008 | 01:34 PM
mercutio_07's Avatar
Default T bracket?
Is there any way to replace the rear mount without removing the T bracket it's mounted to? I did a search, but nothing came up of any use.
Old Mar 19, 2008 | 01:40 PM
Blk00EJ8's Avatar
Default Re: T bracket? (mercutio_07)
If you can get your hands in there to unbolt the bolt that attaches the T bracket to the mount and the 3 bolts from the rear mount to the subframe, then yes. It is ridiculously difficult to unbolt the T bracket from the mount, though. I've tried.
I would say it might be easier going in from underneath, unbolting both the rear mount and T mount, then dropping it down. Requires some finaggling to get it out, though.
Old Mar 19, 2008 | 02:52 PM
Default Re: T bracket? (Blk00EJ8)
that's just it though...i've gotten in there and taken out all the bolts attached to the mount (definitely a pain in the a$$), but there's a hose in the way from me pulling it out, even when the hose is off it's attachment sticks out too far and that's in the way.
Old Mar 19, 2008 | 04:14 PM
up
Old Mar 19, 2008 | 04:18 PM
Bakeoff's Avatar
Why are you against taking out the T bracket? From under the car, it's just 4 bolts. Very easy. Then remove the rear mount, replace, and throw 4 bolts back in. It's pretty darn simple.
Old Mar 19, 2008 | 04:35 PM
Default Re: (Bakeoff)
I'm not against it, just didn't know if there was a way to take out the mount without taking that out. After enough failed attempts to get it out without taking off the T i would've taken it off, but it started raining...
Arthas
Jul 23, 2010 01:38 PM
93JDM_H22
Jul 1, 2010 12:04 AM
mateo5046
Apr 14, 2008 01:04 PM
91BlueEF9
Sep 8, 2007 07:00 AM
XkjeldorX
Jun 21, 2006 01:49 PM
