Weird, please help
Old Mar 19, 2008 | 12:22 PM
JUN.'s Avatar
Default Weird, please help low compression after adding carb cleaner?
Hi, I bought a b16A and I did a compression test before I installed on the car. It turned out good on all cylinders around 235-210.
Now after swaping, I did a compression test again because I was bored and it came out low compression on cylinder 1... WTH ?
all I did was to spray some carb cleaner on the intake manifold a couple of days ago.
Now cylinder 1 has 90 compression. I added a little of engine oil on that cylinder and it turned up to 240 psi. So I guess my rings are bad.......
Why would this happend?
Shouldn't carb cleaner be like fuel?
Modified by JUN. at 8:37 PM 3/19/2008
Old Mar 19, 2008 | 01:49 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Weird, please help (JUN.)
How long from the time you sprayed carb cleaner to the time you did the compression test?
Old Mar 19, 2008 | 02:20 PM
JUN.'s Avatar
Default Re: Weird, please help (Maxbore.com)
around 2 days ago I sprayed carb cleaner into the manifold but most of it went to cylinder 1. Also my first compression test was around 12 days ago.
Modified by JUN. at 7:57 PM 3/19/2008
Old Mar 19, 2008 | 02:23 PM
Jonny Rocket's Avatar
Dat is weird....you sure you installed the tester right?
Old Mar 19, 2008 | 02:34 PM
JUN.'s Avatar
Default Re: Weird, please help (Jonny Rocket)
I did, and I took it out, put it back re-test 2 or 3 times........
the only thing that was out of the engine when I took the compression the first time was the oil dip stick....
Old Mar 19, 2008 | 03:17 PM
JUN.'s Avatar
**** Update
Ok so I added carb cleaner to see if my compression decreased on the other cylinders and it did.... now 2 and 3 has 60 psi and 10 psi compression.... I know that you guys might think that I might be crazy on doing such thing..... But if 1 was bad, then I was going to replace all rings.
But shouldn't carburetor cleaner be safe for pistons ?
I am starting to believe that carb cleaner decreases compression due to the oil residuals or thickness? it makes the rings loose compression ?
Or that my compression tester is bad (full of oil)
Modified by JUN. at 8:39 PM 3/19/2008
Old Mar 19, 2008 | 04:41 PM
JUN.'s Avatar
hopefully, when I get my ecu, Ill start the car and all that cleaner crap will burn.
Old Mar 19, 2008 | 04:43 PM
Damn lol Idk dude. My guess is that the carb cleaner cleans off the carbon n **** off the rings...
Old Mar 19, 2008 | 05:09 PM
No Big Whoop
The carb cleaner removes the oil from the cylinder walls, then the oil rings don't seal as well. stop spraying that stuff, you could be doing damage to the cylinder walls.
Old Mar 19, 2008 | 05:12 PM
JUN.'s Avatar
ok but what about the compression rings?
Shouldn't I be getting high compression readings?
Old Mar 19, 2008 | 06:20 PM
JUN.'s Avatar
Help PPL
Old Mar 19, 2008 | 06:23 PM
No Big Whoop
Just drive the car, don't spray carb cleaner.
then do the compression test again. Make sure to open te throttle as you crank.
You cannot have the injectors spray fuel as you do the test, that will skew the results. Disconnect the fuel pump.
Old Mar 19, 2008 | 06:31 PM
zrickety's Avatar
yea, stop spraying the cleaner until you get it running. i would try a few drops of oil in each spark plug hole, crank it over and try to get some oil pressure back in there. do another test after that maybe
Brandon Peters
Oct 18, 2015 05:37 PM
rich045
Jun 13, 2007 12:23 PM
dreamreaperx
Dec 20, 2006 02:01 PM
greenli0n25
Jan 26, 2004 07:29 AM
Chubz
Jun 27, 2002 02:00 PM
