Decided To Pull Block Apart And Look What I Found
Old Mar 19, 2008 | 11:36 AM
D16SohcVtec's Avatar
Default Decided To Pull Block Apart And Look What I Found
So since it's spring break for me, I decided I should go and pull apart the b16a block that I had laying around. My buddy pulled this block from his CRX that he just bought and wanted to throw in his boost ready motor so he didn't want the stock b16a so he gave me the block.
My plan was to build this block for boost and after I take everything out look what I find on rod number 2.
Old Mar 19, 2008 | 11:41 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Decided To Pull Block Apart And Look What I Found (D16SohcVtec)
How scored up is the bearing cap?
Old Mar 19, 2008 | 11:43 AM
crazyguy's Avatar
oh my
Old Mar 19, 2008 | 12:09 PM
billyinse's Avatar
was that being driven ?
Old Mar 19, 2008 | 12:25 PM
Default Re: Decided To Pull Block Apart And Look What I Found (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
How scored up is the bearing cap?</TD></TR></TABLE>
It's pretty scored up. I was dissapointed when I saw that. Even when it was still on the crank you can see pieces sticking out everywhere. Good thing I got this block as a gift or I don't even know how mad I could be right now.
What do you guys think about that crank? I guess I just got myself a oversized paper weight
Yes apparently it has been driven for a while like that. My buddy said it ran find when he just bought the car, but smoked a bit. Didn't think there was this much damage to it.
Old Mar 19, 2008 | 12:45 PM
Bakeoff's Avatar
Get it line bored, repair the crank and get oversized bearings. Game on. Way cheaper than buying a used block.
Old Mar 19, 2008 | 01:00 PM
Default Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">Get it line bored, repair the crank and get oversized bearings. Game on. Way cheaper than buying a used block.</TD></TR></TABLE>
I was also thinking about doing this, but then again just getting a new use block is better assurance then repairing this and having the thought on the back of your head. Besides the block needed to be overbored 20 over since cylinder one was kinda beat up.
Old Mar 19, 2008 | 01:05 PM
egb18c5's Avatar
not tryin to come off wrong but i think that would cost more than finding a used bare block, and b16 cranks are pretty cheap
Old Mar 19, 2008 | 02:22 PM
highrev1987's Avatar
Default Re: (egb18c5)
line boring is only necessary when you do that to a crank bearing. i wouldnt 'repair' that crank because if you want to put power to it, cutting the crank would remove the nitride coating so find a cheap used crank have it balanced and throw some forged goodies in there, then have a beer
Old Mar 19, 2008 | 03:59 PM
EJ8freek's Avatar
That looks nasty.
Old Mar 19, 2008 | 04:09 PM
faxshatch's Avatar
Default Re: Decided To Pull Block Apart And Look What I Found (EJ8freek)
Ouch i aint never seen that before!
Old Mar 19, 2008 | 04:19 PM
muasboi's Avatar
Default Re: Decided To Pull Block Apart And Look What I Found (faxshatch)
haha, crazy!!
Old Mar 19, 2008 | 04:30 PM
Brick Top's Avatar
Default Re: Decided To Pull Block Apart And Look What I Found (muasboi)
the crank doesn't look bad at all. take it to a machine shop.
I had mine cut 20 over and it's been running great for 20k miles
Old Mar 19, 2008 | 09:28 PM
Default Re: Decided To Pull Block Apart And Look What I Found (Brick Top)
Two other main bearings had bad wear on them too. Like it was low on oil or something I don't know. But, I just got rid of it because I knew I wasn't going to use it anymore.
turbodisel37
May 13, 2008 06:31 PM
tsnunderground
Southeast (Sales)
Feb 4, 2006 11:41 PM
apexii
Oct 3, 2002 09:47 AM
stayontrack
Sep 20, 2002 03:04 PM
