jdm hub question
k just swaped the jdm hubs on my type r heres my problem it has no where to put the abs sensors on and i disconnected it now my abs light is on what can i do to fix this and make my abs work?
Are you sure your looking in the right place, because the LS with the JDM 5 lug had no problems with getting the abs setup/installed when doing the conversion.
Maybe im not understanding what your saying.
Ali
Ali
yea i disconnected the sensor from the harnes because on the hubs its got no where to mount it idk u wanna come over or ill go see u and u can take a look and see what u think ?
Ill try to stop by this weekend, but your welcome to come over anytime.
I have a spare JDM 5 lug for the R in the garage. Ill see if i can pull it out and take some pics of it later.
Ali
Ali
I just put in a JDM 5 lug a couple weeks ago. I can tell you FOR SURE that there is a mount on the knuckle for the ABS sensor to attach with two little 10mm bolts. It mounts exactly the same as on the US knuckle you took it off of.
not all jdm 5 lug's had abs. I have personally had 2 setups, one with one without. If I remember correctly everything is there but the holes arn't drilled and taped to mount the sensor and the axles didn't have a tone ring. I THINK you can drill and tap, mount up your usdm sensors and call it a day, or swap with someone who doesn't need abs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjones »</TD></TR><TR><TD CLASS="quote">prolly a stupid question but dont mean to thread jack, but is there way you can swap out a 36mm hub and stay 4x100?</TD></TR></TABLE>
Yes.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">
Yes. </TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">You have the 36mm or 32mm hubs? </TD></TR></TABLE>
36 mm hubs
36 mm hubs
josh-roy
Jul 30, 2010 02:32 AM
