94 prelude warm up issues
Old Mar 19, 2008 | 10:02 AM
the ludee's Avatar
Default 94 prelude warm up issues
I have a 94 honda prelude si with a rebuilt motor in right now and it has a few problems.
It only warms up to the first bar usually and will only warm up to the middle if i sit in my car for about 10 minutes and if i start driving it will go back down to one bar. and even when it goes up to one bar it takes a long time around 7 minutes in 65 degree weather. when warming up it idles around 1500 rpms.
also i had all my accessory belts and timing belt changed and i've been driving for about 3000 miles and the belts are still whining is that right? it is a loud whine i cant exactly tell which belt its coming from but its noticeable at all rpms.
Old Mar 19, 2008 | 11:43 AM
JasonST's Avatar
Default Re: 94 prelude warm up issues (the ludee)
Replace the thermostat, it's the only problem that can cause that, besides your radiatior fan being stuck on all the time which it sounds like it isn't. Replace it yourself it's only like 10 bucks. As far as your belts, make sure they're not too tight or too loose, that'l cause em to squeel and make all sorts of sounds.
Old Mar 19, 2008 | 01:55 PM
the ludee's Avatar
Default Re: 94 prelude warm up issues (JasonST)
alright so i'll check into the thermostat (the fans switch on as the should)
and do i need anything special to adjust the belts is there a way to know if its too tight or too loose?
they dont seem loose and i dont know what too tight is.
Old Mar 19, 2008 | 02:02 PM
Acidcrakker's Avatar
Rule of thumb I use for the belt is
1. Its on there just right when you can twist the belt only 90 degrees while its on the motor.
Old Mar 19, 2008 | 05:52 PM
the ludee's Avatar
Default Re: 94 prelude warm up issues (Acidcrakker)
k thanks anyone have any more input?
Old Mar 19, 2008 | 06:05 PM
the ludee's Avatar
alright i just checked and the skinnier of the 2 accessory belts can twist upside down and the other is at about 90 degrees. also which way do i twist the bolt to tighten? and if i tighten it will it tighten both? and would it being loose make it whine? (just to be sure since this is my last post for today.)
any other information would be helpful since i cant post anymore today.
Old Mar 19, 2008 | 07:51 PM
prelude_h22vtec's Avatar
you shouldnt worry about the belts much. the warm up problem is def the thermostat. its what controls the temperature. keeps the coolant in the specified range.
Old Mar 20, 2008 | 09:09 AM
the ludee's Avatar
Default Re: (prelude_h22vtec)
why not worry about belts?
becides the annoying *** noise i heard if they are too tight they can cause quicker wear then regular.
Old Mar 20, 2008 | 11:17 AM
the ludee's Avatar
Default Re: (the ludee)
anymore insight on the belt whine??
Modified by the ludee at 3:12 PM 3/20/2008
AudioFunk
Oct 31, 2013 12:06 AM
djoronen
Apr 20, 2009 05:53 PM
CSTMGP
Mar 7, 2004 05:38 PM
shyboy_02
Nov 17, 2003 09:30 AM
