b16 sedan issue
I did my timing belt yesterday bacause it was off about 4 teeth which i thought was the reason for my bogging issue. I did a new belt and tensioner and the single grove is lined up with the cover and the cams are both up and set correct and the car got worse. It only runs for a couple seconds missing really bad and dies out and will not pass 2500 rpms. I could really use some help on this its driving me nuts. again single mark on pully is lined with the mark oncover and both gears up and all. Dizzy on cyl #1? any help? anyone?
Ive done that already it runs a little better turned fully advanced almost like the timing is off but the gears and lower pully are lined up correctly. bottom pully is set to the single line with both cams set correctly.
Yeah i am the car seemed to run better when the timing was 4 teeth off, When the cams were aligned the lower gear was about an inch and a half off twords the front of the car once i got it set right it got way worse
for sure bro and thanks for your help man its hard to get tech help here unless you have a h22 turbo build lol but again thanks ill do that tonight. after i get off work.
when lower mark is even with single notch on the lower pully both cams are up with marks alligned. also dizzy was centered but it runs better pulled to one side which i dont get all marks are lined up.
Modified by B16acivicsedan91 at 4:20 PM 3/20/2008
ok so i get under my hood last night. used a long screw driver to find tdc on my this pos and come to find out my marks on my pully are off by a world of difference. Ill have to find out why at some dther but ill be working on that now and keep you poster
hybrid1990crx
Aug 20, 2011 06:10 PM
Declectic
Sep 24, 2004 09:39 PM
JDMflavor_EJ
26
Apr 2, 2004 04:49 PM
What's your ignition timing look like?
