are 94 gsr axles same as 95 ls axles?
Old Mar 18, 2008 | 11:01 PM
elliotEk's Avatar
Default will gsr axles fit a ls?
I'm having trouble fitting gsr axles onto a ls. just wonder if anyone else had this problem because I was told they were the same but when I compare the 2 the gsr seems a bit longer. is it still possible to put them on?
Modified by elliotEk at 8:38 PM 3/29/2008
Old Mar 19, 2008 | 12:36 AM
VRD^sam's Avatar
Default Re: are 94 gsr axles same as 95 ls axles? (elliotEk)
I have 96 gsr axles in my 94 ls i dont see why it wont fit
Old Mar 19, 2008 | 12:42 AM
BlueIntegraBoy's Avatar
They are the same. Are you sure you have the correct axle?
Old Mar 19, 2008 | 06:07 AM
crazyguy's Avatar
just make sure if u have abs system cause abs and non abs axles are a bit different. and i am not sure if all 94 and up integra are equipped with abs as standard or
Old Mar 19, 2008 | 09:00 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: are 94 gsr axles same as 95 ls axles? (crazyguy)
Are the part numbers the same? You can look them up on the Delray Acura website. If the part numbers are the same, then they are interchangeable for sure. If the part numbers are not the same, then they may or may not be interchangeable.
Old Mar 19, 2008 | 11:09 AM
91redteg's Avatar
Default Re: are 94 gsr axles same as 95 ls axles? (nsxtasy)
the abs and non abs are different. if u have the abs axles, but no abs. u can modify the abs axles to work
Old Mar 19, 2008 | 11:35 AM
elliotEk's Avatar
well I bought a integra shell which came with non abs system off an eg but I converted them back to stock integra abs system and I was told by the guy I bought the shell off that they were the stock gsr axles. I compare it with my ls axles and they look exactly the same except the nose that goes into the rod is about an inch longer. thanks for the info fellaz.
arsenaldragster
Apr 24, 2005 10:49 PM
j0nptw
Feb 18, 2005 10:12 AM
b18bvudoo
Oct 27, 2002 08:38 AM
boomslang
Jun 2, 2002 09:45 PM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
