A/C problems
Old Jul 8, 2002 | 06:27 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default A/C problems
My 97 TypeR A/C only works on 1.Somtimes it will work on 2.3 & 4 the compressor just goes on and off over and over.Does anyone know where to tell me to look first?Thanks!
Old Jul 9, 2002 | 10:11 AM
CivicNewbie's Avatar
Default Re: A/C problems (turbotypeR)
check to see if you have enough freon on your system. The low side should read about 35-35 psi, high side ~ 170 psi.
Old Jul 9, 2002 | 10:28 AM
TypeSH's Avatar
Default Re: A/C problems (CivicNewbie)
maybe u have too much freon or air in system.
Old Jul 10, 2002 | 04:32 PM
25 Year Member
Default Re: A/C problems (TypeSH)
i have had two people look at it and one remove freon and said i did have too much but they evacuated it and now it should have the correct amount.even when it had too much it worked on 1 & 2 and not on three and four.i have been through the service manual and can't seem to find anything that will help me.
Old Jul 13, 2002 | 12:32 AM
civicsportline's Avatar
well i have a 00' honda, and the AC compressor siezed, and the clutch assembly sheered right off. now i need 750.00 for a new one. how about that? be glad it works at all! it's 118' in AZ.
faran
Jul 22, 2013 05:09 PM
HNP
Honda Civic (2001 - 2005)
11
Jun 14, 2008 05:59 AM
gamblezhang83
May 18, 2008 04:46 AM
ABCVTEC
Oct 11, 2007 10:02 AM
