my front rotors are loose????
Old Mar 18, 2008 | 08:48 PM
jdmekrobot's Avatar
Default my front rotors are loose????
i recently got a different car, its just the shell. and all the brakes were switched before i got it. and now both front rotors are loose? they are tightened on and the calipers are tightened. i tried bleeding the brakes, but it seems like the calipers arent working. should the rotors be loose even if the calipers are froze up? do the calipers and brake pads keep the rotors from moving? and does the fact that there is no axle make the rotors not stay in place?
Modified by jdmekrobot at 8:47 AM 3/19/2008
Old Mar 18, 2008 | 09:19 PM
Midori Green's Avatar
Default Re: my front rotors are loose???? (jdmekrobot)
no the caliper does no hold down the rotor... your wheels do, so when you install new rotors they are loose sometimes but once you slap that wheel on and tighten thats it everything will work fine.. just make sure the 2 caliper bolts are tight (14mm) and the 2 caliper braket bolts are also tight (17mm) when they did the brakes they pushed the piston in the caliper back meaning the pad is off the rotor so when your all done and you hit the brakes it will return to its position and will brake on the rotor
Old Mar 18, 2008 | 09:20 PM
Dee888's Avatar
Get new calipers. The piston should push out once you pump the breaks and push the brake pad to the rotor and making it all tight .
Old Mar 19, 2008 | 05:48 AM
jdmekrobot's Avatar
Default Re: my front rotors are loose???? (Dee888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">no the caliper does no hold down the rotor... your wheels do, so when you install new rotors they are loose sometimes but once you slap that wheel on and tighten thats it everything will work fine.. just make sure the 2 caliper bolts are tight (14mm) and the 2 caliper braket bolts are also tight (17mm) when they did the brakes they pushed the piston in the caliper back meaning the pad is off the rotor so when your all done and you hit the brakes it will return to its position and will brake on the rotor</TD></TR></TABLE>
could it also be loose cause there are no axles?
Old Mar 19, 2008 | 06:50 AM
em1allday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmekrobot &raquo;</TD></TR><TR><TD CLASS="quote">
could it also be loose cause there are no axles?</TD></TR></TABLE>
no the axles dont hold the rotor in place
Old Mar 19, 2008 | 07:57 AM
blkegcoupe's Avatar
From: ....................................................................................................
Default Re: my front rotors are loose???? (em1allday)
there are 2 screws that hold in the rotor onto the hub not caliper
Old Mar 19, 2008 | 10:05 AM
mikeycivic's Avatar
Default Re: my front rotors are loose???? (blkegcoupe)
you dont need those 2 screws. The lug nuts and wheels will hold the rotor on without the need of the 2 screws.
Modified by mikeycivic at 2:21 PM 3/19/2008
Old Mar 19, 2008 | 10:18 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe &raquo;</TD></TR><TR><TD CLASS="quote">there are 2 screws that hold in the rotor onto the hub not caliper</TD></TR></TABLE>
thats right .but it was only made for assembly line at honda factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">you dont need those 2 screws. The lug nuts and wheels will hold the caliper on without the need of the 2 screws.</TD></TR></TABLE>
thats true too
Old Mar 19, 2008 | 12:26 PM
jdmekrobot's Avatar
Default Re: my front rotors are loose???? (crazyguy)
just looked at it again and everything is tight. the rotor and caliper move even when the wheel is on? the center thing that the axle slides into moves too, thats bad isnt it? i forgot what bearing or whatever it is is called.
Old Mar 19, 2008 | 12:29 PM
mikeycivic's Avatar
when you say move, what exactly s moving? The whole wheel/rotor/brake assembly?
Old Mar 19, 2008 | 12:46 PM
Malakai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmekrobot &raquo;</TD></TR><TR><TD CLASS="quote">just looked at it again and everything is tight. the rotor and caliper move even when the wheel is on? the center thing that the axle slides into moves too, thats bad isnt it? i forgot what bearing or whatever it is is called.</TD></TR></TABLE>
Sounds like your wheel bearing is shot.
Old Mar 19, 2008 | 01:08 PM
egb18c5's Avatar
Default Re: my front rotors are loose???? (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like your wheel bearing is shot. </TD></TR></TABLE>
x2
Old Mar 19, 2008 | 01:22 PM
jdmekrobot's Avatar
Default Re: my front rotors are loose???? (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">when you say move, what exactly s moving? The whole wheel/rotor/brake assembly?</TD></TR></TABLE>
the rotor, the center part where that the axle slides into and the caliper part that moves up so you can get to the pads moves.
Old Mar 19, 2008 | 01:29 PM
mikeycivic's Avatar
this is really hard to understand, but I do think its your wheel bearing as well.
Old Mar 19, 2008 | 02:28 PM
jdmekrobot's Avatar
and how do i replace those?
shwepes
Suspension & Brakes
Jan 23, 2016 06:17 PM
drewbie
12
Aug 25, 2007 09:14 AM
lude98SH
Sep 24, 2006 04:02 AM
strepto
Aug 6, 2003 08:20 AM
