Ipod connection to Alpine HU questions
Old Mar 18, 2008 | 07:24 PM
civhatch90's Avatar
Default Ipod connection to Alpine HU questions
Hello all,
I want to connect an Ipod to a cdm-7854 Alpine HU.
If I use this: http://www.crutchfield.com/S-K...M123B
Will I be able to control the play list from the HU?
Will the sound quality be decent?
Is there any other possible set ups i could use? (no FM signal connections)
Last question, if i do get that kcm 123b i will have to pull the already installed Alpine HU from the console. Now i remember when i installed it that it has two clips on one side so that it will not slide back out of place, how would i go about pulling it out from the dash?
Thanks!
Old Mar 18, 2008 | 08:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ipod connection to Alpine HU questions (civhatch90)
No.
It will be OK, an iPod docking port adapter would be better.
Yes. re: last question.
That will depend on the MM&Y of car it is.
If it's a 90 Civic, you may be able to reach up behind and plug the adapter in. 94
Old Mar 18, 2008 | 09:37 PM
BimmerM3's Avatar
Default Re: Ipod connection to Alpine HU questions (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think they ever made a dock connector for Alpine models with M-bus.
This may be your only option without getting a new HU.
Old Mar 19, 2008 | 05:11 AM
civhatch90's Avatar
Ok guys, thanks for the quick responses. It seems like that cable will be the only alternative without getting a new HU and its cheap enough to make it worth a try.
Now unfortunately this is not my civic where i can reach around the back of the console and get to the radio, the car in question is a 98 Contour. Any ideas on how to get the HU out?
Old Mar 19, 2008 | 06:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: (civhatch90)
Remove the trim bezel and "lift" the locking pins 1/2 way up the "hooks they are in and pull unit out.
If the locking pins will not move the may be binding because there is pressure on them, push in on the unit a little as you lift the pins. 94
Old Mar 19, 2008 | 05:40 PM
civhatch90's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Remove the trim bezel and "lift" the locking pins 1/2 way up the "hooks they are in and pull unit out.
If the locking pins will not move the may be binding because there is pressure on them, push in on the unit a little as you lift the pins. 94 </TD></TR></TABLE>
Ill give it a try. Thanks
Old Mar 19, 2008 | 07:24 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BimmerM3 &raquo;</TD></TR><TR><TD CLASS="quote">
This may be your only option without getting a new HU. </TD></TR></TABLE>Yes they do.
The Pac id-ALPM... http://www.pac-audio.com/produ...ation
The PIE ALP/M-POD... http://www.pie.net/pie_store/s...cific
The Peripheral PXA03... http://peripheralelectronics.c...earch=
There are probably others. 94
Old Apr 6, 2008 | 07:01 PM
civhatch90's Avatar
Is this the dock connector you are talking about? http://www.pie.net/pie_store/s...bc=no
So the advantage it has over the kcm 123b is better quality and charging?
Old Apr 7, 2008 | 05:21 AM
fcm's Avatar
fcm
Old Fart
You have an IM. 94
Old May 14, 2008 | 08:37 AM
civhatch90's Avatar
ok, i finally got around to installing the cable but I have not been able to hear the music playing through it. How do I switch the HU to aux mode?
djsns811
Honda S2000
13
Oct 21, 2008 03:30 PM
BimmerM3
Audio / Security / Video
Mar 27, 2008 09:07 PM
p nut
Oct 9, 2005 08:17 PM
loki2323
12
Aug 14, 2003 09:51 AM
CalvitoSol
Jul 12, 2002 02:01 PM
