FS: BNIB Drag Generation 3 Turbo Kit
B Series Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
Blitz blow-off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
All above kits work with automatic or manual transmission.
All above kits will work with A/C.
$2500obo
Modified by Tinberland21 at 12:32 PM 4/7/2008
Oil return assembly
$2500obo
Do you have any pics of the actual items...not to put you down, but the reason this stuff has not sold yet, is probably because anyone could just take the pictures from the drag website, and say "I have a drag turbo kit for sale." I would make you a good offer on this, but soemthing seems strange. Please post real pics if you have some. Thanks!
Nothing is missing at all. I don't get what's so strange about it but yeah I can take real pics no problem. I will post them later today definately.
Tinberland21
Apr 6, 2008 06:19 PM
