car wont start
i have a 1991 honda accord wagon. it ran 2 days ago but yesterday i went to start it and it wouldn't. the battery is fine and it turns over but it just wont start. what are some things i can check or replace to wake my baby up?
please help
please help
Can you hear the fuel pump run a couple seconds when you turn on the key?
Is there fuel pressure at the test port on the fuel rail?
maybe you could pull a plug wire loose from the dist cap, hold the end about 1/4" from the terminal with insulated pliers, have someone crank the engine to check for spark.
If you have a cheapo test light/multi-meter there are some easy diagnostic tests.
Repost and people might have other things you can check once the basic info is available.
A correct and accurate diagnose can save you some cash.
chickendance
Mar 12, 2012 03:48 PM
JDM Freakk
Jun 21, 2011 05:36 PM
4gencivicef9
Jun 26, 2007 04:12 PM
