HUGE Problem with Idle!
Old Mar 18, 2008 | 02:01 PM
dcskater56's Avatar
Default HUGE F****** Problem with Idle!
i have a 1991 accord with f22a. there is something major f-ed in my throttle body. heres what happens: when i started it up today and my rpms sitting in nuetral idling were up to like 7k. then after looking around the engine compartment for a while i discovered that there was a vacuum hose going from the cruise control accuator to the throttle body that had been blown loose or whatever so i plug it back in and my idle went down to about 3500 and so i pumped the gas a few times and no my idle is between 2 and 2500... but now when i put it in gear and start to push the gas my rpms shoot up past 5k and stay high for a while then go back down. I NEED SOME HELP HERE!!!!
Modified by dcskater56 at 3:10 PM 3/18/2008
Old Mar 18, 2008 | 02:47 PM
dcskater56's Avatar
Default Re: HUGE F****** Problem with Idle! (dcskater56)
nobody has an ideas at all?????????
Old Mar 18, 2008 | 03:01 PM
Slomies's Avatar
bumping your thread only after 46 min? gotta give people a chance to post lol
is your idle just sitting at at high rpms or is it jumping from like 1k to 5k to 1k to 5k? if it's jumping, you might have to remove the fitv and take off the one side of it and tighten the piece on the inside down.
it's #8 in this picture ...
Old Mar 18, 2008 | 03:18 PM
gianinline's Avatar
My friend had his car idling at 2k to 3k rpms... sometimes a little higher... and the #8 on the picture as mentioned by fellow Slomies turned out to be the solution, better yet, no part had to be replaced or bought new.
Old Mar 18, 2008 | 03:20 PM
dcskater56's Avatar
Default Re: (Slomies)
no its sitting at high idle i have managed to get it to sit at about 2 to 2500 at start up but it doesnt go down to where it should after heating up. but if i try to drive the car putting it into gear and pushing gas down while clutch is in the rpms go to like 5k. and stay up then for a while then go back down some......
Old Mar 22, 2008 | 09:36 AM
mross's Avatar
Check the fast idle valve, it may be sticky. You may want to open the 2 screw on-top and adjust the valve. I did that for my accord.
Old Mar 23, 2008 | 10:13 PM
HennessyLane's Avatar
Default Re: (dcskater56)
All you have to do is clean the fast idle valve Break cleaner will do the job i had the same thinig happen to me took me a year to find what it was. I would show a Pic but i don't know how to upload then. make shor the yellow thing is down all the way.
Old Mar 24, 2008 | 06:44 AM
romeoz24_2000's Avatar
dcskater I have OWN A 1991 HONDA ACCORD SE AND i HAD THE SAME PROBLEM AS YOU ARE HAVING i BROUGHT IT TO THE DEALER AND THEY REPLACE THE PART NUMBER#8 IN SLOMIES PIC AND IT FIX THE PROBLEM.GOOD LUCK
Biggs_Drums
Apr 22, 2009 02:28 PM
mad21kid
Feb 18, 2008 12:52 PM
f22abuilder
Feb 7, 2006 09:29 AM
gutted-dx
Dec 18, 2005 09:08 PM
stRodda
Jan 13, 2004 04:32 PM
