Honda S2000 Honda S2000
OEM Navigation Troubleshooting, Would like some info on JDM S2000 Navi
Old Mar 18, 2008 | 11:52 AM
lees2000's Avatar
Default OEM Navigation Troubleshooting, Would like some info on JDM S2000 Navi
I have read a lot about trying to get an OEM s2k navigation system into non navi cars. However I have a different problem. I have a 99 JDM S2000 import with DVD navi and I am interested to see if I can get it to work. I am aware of the potential problems with discs etc. but my problem is more fundimental. Although I have power to the screen and DVD unit, I don't get any startup screen, the screen remains blank. The original head unit has been replaced with an aftermarket unit, leaving the audio connection (mute etc) disconnected. I am not sure if this would cause a problem (I havent been able to get a JDM 2000 wiring diagram).
The other issue is that I only have US/EUROPE DVD discs. Are these wholly incomapatible and is a disc needed before the initial splash screen is displayed?
I am just interested to see how far I can get with this, so any help, diagrams etc. would be much appreciated. BTW I have tried using the diagrams from the Odyssey and although the pin-outs on the DVD and screen units are the same the wiring doesn't appear to be the same?
Old Mar 18, 2008 | 09:25 PM
veilside_s2k's Avatar
Default Re: OEM Navigation Troubleshooting, Would like some info on JDM S2000 Navi (lees2000)
check out s2ki.com
Old Mar 20, 2008 | 10:30 PM
jeffchaisi's Avatar
Default Re: OEM Navigation Troubleshooting, Would like some info on JDM S2000 Navi (veilside_s2k)
my is working
Old Mar 21, 2008 | 09:13 AM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilside_s2k &raquo;</TD></TR><TR><TD CLASS="quote">check out s2ki.com</TD></TR></TABLE> s2ki blows no one wants to help unless they know the problem they dont even try can you get an market GPS that will fit in place like the OEM one?
Old Mar 23, 2008 | 03:59 AM
lees2000's Avatar
Default Re: OEM Navigation Troubleshooting, Would like some info on JDM S2000 Navi (jeffchaisi)
IF you have this working... a couple of questions
1) If you remove the dvd disk, do you get anything on the screen if you turn the ignition on i.e. does the unit boot at all (splash screen)?
2) Are you using a JDM dvd disk? If not does a us/european work ok?
3) if its jdm, have you got a source for these disks, so i can try one?
Old Mar 25, 2008 | 02:36 PM
jeffchaisi's Avatar
when u remove the dvd disk my screen still show boots up it just say no disk. but i can still use my tv tuner.
i am using the JDM disk right now i have not tried any us disk yet.
i am sure some one can make a copy of my dvd navi disk for a small fee.
Old Mar 25, 2008 | 09:42 PM
jeffchaisi's Avatar
in navy mode:
out of navy mode: turn to tv tuner mode
pic of the dvd navigation in the trunk which i have no time to finish the install yet. still need to be bolt down and clean up.
this is out of a VGS JDM s2k
hope this helps
Old Mar 26, 2008 | 10:13 PM
bigsam2k's Avatar
JUST GET A JVC NX5000 HEAD UNIT! IT HAS A BUILT IN NAVI!
Old Mar 29, 2008 | 10:16 AM
lees2000's Avatar
Thanks for the info and pics...
One question you seem to have an aftermarket head unit in there.
I have a kenwood fitted to mine and the navi connector had to be left disconnected (this is used in the OEM head to put the navi voice over the speakers).
In you setup have you got and sound? Is the connector used? If not has it been linked in somehow?
If my screen is not bad, the only thing I could think of is that the head unit somehow powers up the screen. I which I could get hold of a wiring diagram to sort this out
entity8888
Jul 31, 2015 10:29 PM
lees2000
Honda S2000
Apr 9, 2008 09:57 AM
