gsr motor problems....rebuildable?
Old Mar 18, 2008 | 09:36 AM
cfwthb_94's Avatar
Default gsr motor problems....rebuildable?
I'm looking into a gsr motor, that had engine problems. Apparently it started knocking when he was driving it, and shut it down. Don't know what exactly is wrong with it, it's not my motor. My question is, if there's no holes coming out the block, the motor cranks over but doesn't fire, would this be a good canidate motor to rebuild? What are some things that could happen that would make a motor useless to rebuild? I know it's hard to diagnose, just trying to find out if it's worth the purchase. thanks
Old Mar 18, 2008 | 10:46 AM
all-mtr-teg's Avatar
Default Re: gsr motor problems....rebuildable? (cfwthb_94)
It might have a spun bearing or bent rod or something, but if you plan or using forged rods and crank, it should be a usable block assuming mains were not damaged or block is not cracked. Do a compression test at least before you buy it.
Old Mar 18, 2008 | 12:09 PM
cfwthb_94's Avatar
Default Re: gsr motor problems....rebuildable? (all-mtr-teg)
We tried to turn it over and it cranked, but everytime after that it did less and less. So i don't think that we will be able to get a compression test
Old Mar 18, 2008 | 01:03 PM
Is there antifreeze in the oil? If so, probably a blown HG or something cracked
Old Mar 18, 2008 | 07:55 PM
HmgLauj69's Avatar
warped mains would pretty much make it a useless rebuild
civicsir94
Jun 9, 2008 06:34 PM
atmosphere
12
Apr 8, 2006 02:02 PM
Nextelbuddy
Feb 15, 2004 09:43 PM
nobrakes
Jul 23, 2003 03:45 PM
m3bluegsr
Jan 12, 2003 03:35 PM
