spun ITR
Old Mar 18, 2008 | 07:17 AM
honda_ek9's Avatar
Default spun ITR
how much would it be to fix up a spun ITR block...get it back to just having it run with stock ITR internals...
Old Mar 18, 2008 | 07:28 AM
citrus3000psi's Avatar
Default Re: spun ITR (honda_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">how much would it be to fix up a spun ITR block...get it back to just having it run with stock ITR internals...</TD></TR></TABLE>
Are you talking about after you've spun a bearing?
You never really know what you need to replace fix until you drop the pan. But if your doing the labor yourself it doesn't cost much.
I don't know what the going rate at most shops is but I'd imagine they charge you the most to just pull the motor out/in.
Old Mar 18, 2008 | 07:30 AM
RTW DC2R's Avatar
spun bearing? well that depends if there is damage to the crank journals. some scratches can be micropolished out but if the damage is bad enough youll need another crank. some people will say you can weld or regrind a journal but I have no knowledge of it and would feel more comfortable with a new crank on such a high revving motor.
Syndacate
Jun 12, 2007 05:57 AM
pornstar4777
Nov 17, 2006 01:02 PM
turbotypeR@SPEC
Feb 16, 2006 07:36 PM
swaytec360
Jun 29, 2005 07:44 PM
ildknyli
Aug 3, 2004 08:26 AM
