leaking b16 transmission
Old Mar 18, 2008 | 04:38 AM
jasony0630's Avatar
Default leaking b16 transmission
hey guys, as the title states, my b16 tranny is leaking fluid....
it's kind of a slow leak, but today it just got a little faster...everytime i park my car and leave it for about 20 minutes, i see a little puddle of fluid about 2 inches across right under the tranny drain bolt....
i was thinking it might be a seal and it just has to be torqued down a little more since i flushed the whole tranny today and replaced the drain bolt seal.
let me know what you think.
Old Mar 18, 2008 | 05:13 AM
crazyguy's Avatar
Default Re: leaking b16 transmission (jasony0630)
there is no seal for tranny. check your drain plug and refill plug for any leakage.
Old Mar 18, 2008 | 05:29 AM
wildcat98's Avatar
check axle seals, pull bung and clean off and use a thin bead if grey silicone
Old Mar 18, 2008 | 05:32 AM
crazyguy's Avatar
Default Re: leaking b16 transmission (wildcat98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildcat98 &raquo;</TD></TR><TR><TD CLASS="quote">check axle seals, pull bung and clean off and use a thin bead if grey silicone </TD></TR></TABLE>
yeah that too.
Old Mar 18, 2008 | 11:04 AM
jasony0630's Avatar
ugh....damn, i really hope its not the axle seals...that would be a pain in the ***.
and by seal, i meant "flexible" washer that can crimp...on the drain plug.
i torqued it down a little more this morning and i found out it wasn't really torqued down enough to begin with....so i hope that solves it.
it's still dripping a little but not as much as before....so i dont know.
wish me luck on finding this [freak]ing leak.
mojackson2390
Aug 17, 2008 07:41 PM
invisible
Mar 11, 2007 09:35 PM
vtec25
Mar 16, 2006 06:54 PM
bak lee
Dec 3, 2004 08:48 AM
vtekthis
Mar 24, 2004 06:11 PM
