Questions about valve replacement
Old Mar 17, 2008 | 08:57 PM
lmike6453's Avatar
Default Questions about valve replacement
do i have to remove the head?
any good diy to follow?
which to buy and where to get them?
how long does it usually take?
what tools are necessary?
basically give me the whole 9 yards-thanx in advance
Old Mar 18, 2008 | 06:26 AM
crazyguy's Avatar
Default Re: Questions about valve replacement (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">do i have to remove the head?
basically give me the whole 9 yards-thanx in advance</TD></TR></TABLE>
no u dont need to remove the head to do the valve replacement, u just need the right tools, i wsa just trying to find that tool for u on ebay and i dont see it listed right now. but it is around $50~$60. pretty easy tool to use but it is time consuming cause u have to remove one valve spring at one time and do u know how to take out valve cover and loose timing belt and cams,cam gears ?
Modified by crazyguy at 7:31 AM 3/18/2008
Old Mar 18, 2008 | 07:48 AM
jhammond_82's Avatar
Reject Papi
Default Re: Questions about valve replacement (crazyguy)
DIY.
Old Mar 18, 2008 | 08:34 AM
lmike6453's Avatar
yes i know how to change the timing belt and remove the valve cover...that's what got me in this mess...
in the diy it says to skip the steps of changing the valves if the head is still in the car...i don't understand how to do it with the head still in...
Old Mar 18, 2008 | 08:47 AM
lmike6453's Avatar
and does this diy apply to the ls head as well?
Old Mar 18, 2008 | 11:14 AM
HmgLauj69's Avatar
are you talking about the valve seals or the valves themselves. you HAVE to take the head out the remove the valves. as far as the valves seals go, no you dont.
not worth it if there not damage and/or if that's the only upgrade your doing.
Boosted_90Teg
Sep 10, 2011 06:30 PM
WhiteNess
Nov 7, 2005 05:04 AM
mycrx7
Sep 22, 2005 08:03 PM
wing
Mar 28, 2005 01:37 PM
Space Boy
May 30, 2002 12:46 AM
