Putting a f22b dohc into my 95 accord lx.
Old Mar 17, 2008 | 07:37 PM
kentb5368's Avatar
Default Putting a f22b dohc into my 95 accord lx.
I have a 95 accord lx with a f22b non vtec. Im searching for an engine and i have found a f22b dohc. I need to know if this is going to be a direct swap, or do i need to get anything else to do the swap? ecu? mounts? Thanks!
Old Mar 18, 2008 | 11:57 AM
Slomies's Avatar
jdm f22b dohc = f22 bottom + h23 head
9.2:1 compression (h23 = 9.8:1), 160hp/148ft lbs (h23 = 160hp/156ft lbs)
so it's basically going to be like swapping an h23 into your accord.
i think i read somewhere that you can get away with running your stock ecu for the time being, but they recommended a p13, P39(jdm f22b dohc ecu), or one that's chipped to run your motor.
for engine mounts, you're going to need a prelude driver side mount. the rest will work just fine as long as you're not doing an automatic to manual swap at this point too. otherwise you will need the transmission mount also.
the wiring's not hard. just follow a writeup on installing an h22 and forget about vtec and a few other things i believe.
here's an h22 write up:
http://www.hondasociety.com/bo...61998
EDIT: to keep your powersteering, you're going to need a 97+ prelude ps bracket. I forgot to mention that. I removed my ps, so i didn't need the bracket
Modified by Slomies at 5:44 PM 3/18/2008
Old Mar 18, 2008 | 06:52 PM
kentb5368's Avatar
Default Re: (Slomies)
why should i need to change the wiring? shouldnt it be the same because it is f series to f series?
Old Mar 18, 2008 | 09:11 PM
zchatch2c's Avatar
Default Re: (kentb5368)
the f22b wiring is the same and it is a great swap for the money.
Old Mar 19, 2008 | 07:22 AM
h22a_black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kentb5368 &raquo;</TD></TR><TR><TD CLASS="quote">why should i need to change the wiring? shouldnt it be the same because it is f series to f series?</TD></TR></TABLE>
just cuz its f series doesnt mean anything... you would have to change the wiring on an f23 or f20b or even an f22b1 (you have a b2)
Old Mar 20, 2008 | 01:37 PM
kentb5368's Avatar
Default Re: (h22a_black)
so what wiring issues should i be looking forward to with the swap?
Old Mar 20, 2008 | 04:06 PM
steerh67's Avatar
please search, there are people who have done this swap before on here. see if you can message them and ask.
Old Feb 9, 2010 | 09:42 AM
h22junky's Avatar
Default Re: Putting a f22b dohc into my 95 accord lx.
ok i have a jdm f22 doch and having timing belt issues. what timing belt would i use cuz it goes from slack to tight when u turn it manually and when it runs it slaps the timing belt cover. what belt do i need?
Old Feb 20, 2010 | 05:31 AM
Nocture's Avatar
Gsr timing belt
Old Feb 24, 2010 | 07:47 AM
hatchhero's Avatar
gsr timing belt dont work
Old Feb 28, 2010 | 06:42 PM
kbud's Avatar
http://www.tegger.com/hondafaq/f22b/index.html
Ethan2536
Jan 5, 2010 07:24 PM
mongtite
Oct 19, 2008 12:29 PM
mongtite
Oct 19, 2008 12:19 PM
Sq
Apr 22, 2007 08:50 PM
