Will a OBD2 B16a Intake Manifold fit & Work on my OBD0 B16a?
Someone is selling the Intake Manifold from a 99 Si which includes:
-throttle body (needs bolts from TPS sensor need removed, they were broken off)
-injectors (OBD2)
-fuel rail
-IAC valve
-DOES NOT HAVE: TPS or MAP sensor.
So my question is if it will fit, and work properly on my OBD0 B16a. Also would I need to get the tps and map sensor for it ? Thanks!
-injectors (OBD2)
-fuel rail
-IAC valve
Its actually a waste of time. You will have to change the fuel rail due to the iat location so over all it wont be worth it. I would get a itr/ctr if your going through all that trouble.. Just my .2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_b16 »</TD></TR><TR><TD CLASS="quote">Its actually a waste of time. You will have to change the fuel rail due to the iat location so over all it wont be worth it. I would get a itr/ctr if your going through all that trouble.. Just my .2 cents</TD></TR></TABLE>
true. go with ITR
true. go with ITR
What do you mean by changing the fuel rail? Would I use the OBD2 fuel rail? The reason I am looking into this, is because its being sold for $100, and it seems to be my temporary *fix* for my idle. Because my FITV and EACV are damaged, and I can't source those parts. Thats why I wanted to get the 99 si IM, so I would be able to know what parts to get, if something would go wrong. And money is a bit short, but I do agree with you on the ITR/CTR
So I'm still stuck... What would need to be done in order to have the OBD2 IM work on my OBD0 B16a? Is it just plug n play?
There's a OBD0 B16??? Hmm I didnt know or i got a brain fart. It will be a direct swaped but sensors maybe be a tad diffrent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops »</TD></TR><TR><TD CLASS="quote">There's a OBD0 B16??? Hmm I didnt know or i got a brain fart. It will be a direct swaped but sensors maybe be a tad diffrent.</TD></TR></TABLE>
Yep. Came in the EF Civic, CRX and Integra XSi (and others) in Japan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK »</TD></TR><TR><TD CLASS="quote">yes it fits
Is it a direct swap over?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow »</TD></TR><TR><TD CLASS="quote">
Is it a direct swap over?</TD></TR></TABLE>
Yes its pretty direct besides changing the fuel rail..
Yes its pretty direct besides changing the fuel rail..</TD></TR></TABLE>
What do I have to do with the fuel rail? Use the OBD2 one?
JibOnALib
Sep 14, 2005 09:47 PM
