s&w roll cage?
Old Mar 17, 2008 | 05:19 PM
dart2.2's Avatar
Default s&w roll cage?
anybody ordered the 10 point cage from them. web site says pre notched, just wondering how the fitment is. thanks for any help.
Old Mar 17, 2008 | 06:28 PM
hootiehoo's Avatar
Default Re: s&w roll cage? (dart2.2)
this is what i bought for my 1998 jetta....
you can see its a very very basic kit. no special bends. just the minimum.
i ended up going to a local hot rod shop, and they tweaked the kit to fit real well.
i ended up saving like 200$ by buying the kit, rather than just having the shop bend one up. the kit was like 600$.(moly). i just got a main hoop, rear legs, harness bar, and door bars. the door bars and rear legs were perfectly straight.
the main hoop was very basically bent, and short, way short....
they would have done a straight up instal, but the fitment was crap. it would work....but when you figure your gonna do it once, why save a few hundred???
just get it done right and nice.
Old Mar 17, 2008 | 08:15 PM
dmotoguy's Avatar
I have the 10pt for eg coupe, i am just starting to fit it up, should have it all tacked up this weekend, so far from what I can see it fits 95% as much as my last cage that was custom.. not bad for a third or fourth the cost. I'll post some photos as I progress in the install.
Old Mar 17, 2008 | 08:39 PM
RCautoworks's Avatar
Default Re: s&w roll cage? (dmotoguy)
Does a supra count ? Doing one for a customer now. A little different because he has a few options on where to put it. Wanna me to upload pics ?
Old Mar 17, 2008 | 11:27 PM
SwappedTURBOegg's Avatar
Default Re: s&w roll cage? (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Does a supra count ? Doing one for a customer now. A little different because he has a few options on where to put it. Wanna me to upload pics ?</TD></TR></TABLE>do it
Old Mar 18, 2008 | 02:16 AM
dart2.2's Avatar
yes, please do!
Old Mar 19, 2008 | 07:44 AM
Will do, the main hoop is about 1 inch if that from the sides. I'll post some pics up as soon as I make some progress.
Old Mar 22, 2008 | 09:59 PM
Well I can tell you this so far. The cage for this supra was ment to go on the floor plates behind the front seats, we moved it back so the cage now needs to be fabricated to fit. The fitment is not bad by any means though, its not a simple bolt in and weld kit though. The main hoop fits well , we had to shorten it down though because we moved it back on the part where the rear seat would go. All in all if someone asked me if they were thinking about getting s&w cage, I'd tell them to do so.
Old Mar 23, 2008 | 10:45 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Well I can tell you this so far. The cage for this supra was ment to go on the floor plates behind the front seats, we moved it back so the cage now needs to be fabricated to fit. The fitment is not bad by any means though, its not a simple bolt in and weld kit though. The main hoop fits well , we had to shorten it down though because we moved it back on the part where the rear seat would go. All in all if someone asked me if they were thinking about getting s&w cage, I'd tell them to do so.</TD></TR></TABLE>
I think they are a hit or miss man, my hoop was way to wide at the rear pillars, it hit the metal underneath the plastics and had to be bent in, it was also really short and dog legged in alot at the bottom, it was also slightly out of square when you lay it flat but that could of been the shippers fault. It has taken alot of tweaking to get my hoop to an install ready status
Old Mar 23, 2008 | 10:22 PM
Default Re: s&w roll cage? (96 GSR-T)
I have found that to be a common issue with prebent cages. The main hoop either needs to be tweaked in or out, now I don't know how much shipping has to play with that but I also don't think its hit or miss, these companies are using a jig ( I'd hope ) so each cage is going to be pretty much the same for each vehicle.
Old Mar 24, 2008 | 10:49 AM
ExVtec's Avatar
For the normal DIY'r, how are we supposed to "tweak" the main hoop if it's out of shape?
I don't have a tubing bender handy..lol.
Old Mar 24, 2008 | 11:25 AM
dmotoguy's Avatar
Default Re: s&w roll cage? (ExVtec)
take it somewhere or live with it... pre bents have + and - 's
Old Mar 24, 2008 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">For the normal DIY'r, how are we supposed to "tweak" the main hoop if it's out of shape?
You could bend/tweak a main hooop by hand then weld it. If you expect it to be a simple bolt/weld in, don't get it.
Old Mar 24, 2008 | 02:26 PM
96 GSR-T's Avatar
Lol I just got done messing with my hoop at my friends garage, I am about to call SW and make sure they sent me the right one cause it is really messed up. We keep messing with it little by little before we get tired of looking at it, after all this time it still dont fit right.
Old Mar 24, 2008 | 04:16 PM
cluelessmale's Avatar
Default Re: (96 GSR-T)
S&W will fix a issue for free jest need to give them back your old one. I had an issue with the halo, and they fixed it.
Old Mar 24, 2008 | 05:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Lol I just got done messing with my hoop at my friends garage, I am about to call SW and make sure they sent me the right one cause it is really messed up. We keep messing with it little by little before we get tired of looking at it, after all this time it still dont fit right.</TD></TR></TABLE>
What wrong with it ? Sure its in the right spot ? A little more description on whats going on would help, maybe some pics.
Old Mar 24, 2008 | 06:21 PM
96 GSR-T's Avatar
Default Re: (RCautoworks)
What wrong with it ? Sure its in the right spot ? A little more description on whats going on would help, maybe some pics. </TD></TR></TABLE>
The widest part of the hoop is just flat out too wide, it hits the vertical quarter window pillars, which unless I am 4'6 makes the car undriveable because the seat is too far forward. Funny if you look closely, you can see it is out of wack, look how level the harness bar is in relation to the bends on both sides of the hoop.
after having to mess with this ****, I couldnt even imaging trying to assemble a 10pt from them.
Modified by 96 GSR-T at 10:29 PM 3/24/2008
Old Mar 24, 2008 | 06:26 PM
96 GSR-T's Avatar
Default Re: (cluelessmale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale &raquo;</TD></TR><TR><TD CLASS="quote">S&W will fix a issue for free jest need to give them back your old one. I had an issue with the halo, and they fixed it.</TD></TR></TABLE>
I just saw your post, I sent them an email earlier, I am going to try to push to get a new hoop, because the one they sent me is real dogshit.
Old Mar 24, 2008 | 08:39 PM
it sucks that you are far from the I am only 30min so it was nice.
I would ask for the PDF of how the cage is built, to make sure everything is right. If it is to spec make a paint drawing of what you want. My contact was Brian Z at S&W.
Old Mar 25, 2008 | 05:43 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale &raquo;</TD></TR><TR><TD CLASS="quote">it sucks that you are far from the I am only 30min so it was nice.
I would ask for the PDF of how the cage is built, to make sure everything is right. If it is to spec make a paint drawing of what you want. My contact was Brian Z at S&W.</TD></TR></TABLE>
Yea I am about 1 hr or so out of there, if I do drive up there I can always hit up KOP while i am there, will make it worth it I guess.
Old Mar 25, 2008 | 10:00 AM
96 GSR-T's Avatar
well I just got an email back from S&W, lolz
"I've been working with Don on your roll bar issue. We pulled the original PO from safe drives. The roll bar that was ordered was for a 89-94 Nissan 240SX. This is why the main hoop is off.
We have contacted safe drives and are trying to get the issue resolved with them for you.
I will let you know as soon as we have an answer."
Old Mar 25, 2008 | 10:10 AM
hootiehoo's Avatar
well, look at the pictures of the main hoop in my jetta above....
does that look good to you?? its a solid 3in at least away from the roof, and a solid 2.5 on BOTH sides.
Old Mar 25, 2008 | 10:36 AM
96 GSR-T's Avatar
Default Re: (hootiehoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hootiehoo &raquo;</TD></TR><TR><TD CLASS="quote">well, look at the pictures of the main hoop in my jetta above....
does that look good to you?? its a solid 3in at least away from the roof, and a solid 2.5 on BOTH sides.</TD></TR></TABLE>
looks better than the one sitting in my garage, atleast you can get yours in the car.
Old Mar 25, 2008 | 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">well I just got an email back from S&W, lolz
240 is just a little different the an integra
Old Mar 25, 2008 | 02:25 PM
I had problems with my main hoop being too low from the roof(like 3") they wouldn't send me a new one and wanted like 130 shipped for another that was 4"taller on each side so i can cut it how i wanted. so i just bought a roolbar kit for 180ish to get a new hoop for my 10 point . on the initial purchase they were pretty cool because i wouldn't run the around the dash bar so they took my measurements and bent me a though dash bar for no extra charge. not in the car yet but i think im going to have trouble with straight door bars and door panels.
