Tried to diagnose code p1457 evap, now the car wont crank
Old Mar 17, 2008 | 04:34 PM
93dx--hatch's Avatar
Default Tried to diagnose code p1457 evap, now the car wont crank
I tried to test the evap purge control solenoid on my 98 GSR. The helms manual said to jumper 2 pins on the ECU together so I did, by stuffing a wire from the one pin to the next.
It said to start the car and then check for vacuum. Well after I jumpered the wires I tried to start the car, all the lights on the dash came on pump primed, but when I turned the key all the dash lights turned off like the battery was dead. Its a new battery, I threw it on the charger and it was good.
So I take the jumper off and try to start the car....same thing happened.
Checked all the fuses, jumped the service connector and its solid.
Did i burn up my ECU?
Old Mar 18, 2008 | 05:42 AM
Default Re: Tried to diagnose code p1457 evap, now the car wont crank (93dx--hatch)
Bump
Old Mar 20, 2008 | 03:13 PM
anyone, this really sucks,
EFjoe91
Apr 30, 2014 05:49 AM
661rex89si
May 30, 2011 10:56 AM
cheesesuits
Sep 28, 2007 11:45 AM
eskimo10
Apr 25, 2007 08:12 PM
vtecn8ive
31
Jul 1, 2005 07:57 PM
