b16a2 in 92 eg.....HELP!!!!!!!
Old Mar 17, 2008 | 03:52 PM
tigueremalo's Avatar
Default b16a2 in 92 eg.....HELP!!!!!!!
well here is my problem i did my own wiring for the obd2b distributor to run of my stock harness... now with my wiring harness that i did so my distributor could run off my stock harness actually turn the car on now i do have a lounch control but is at like 4500rpms but when i turned on my b16 i took it for a drive with out connecting my knock sensor hopefully is not a problem.. but it didnt pass 3-3500rpms.. thinking that it could of been my wiring i do go back and double check my wiring so i decide to clean up my little mess with the wiring but i finished my harness and now the car doesnt turn on at all it cranks though
what could this problem be now...
(hopefully i didnt fry ma distributor or coil)
any help would be apreciated
thanks in advance
Old Mar 17, 2008 | 03:57 PM
z6hatchboy's Avatar
Default Re: b16a2 in 92 eg.....HELP!!!!!!! (tigueremalo)
Any cels? sounds like it could be a map sensor, or something to do with that launch control. If its bogginh though at the rpm you say, your timing probably just off a lot.
Old Mar 17, 2008 | 04:10 PM
Default Re: b16a2 in 92 eg.....HELP!!!!!!! (z6hatchboy)
but the car ran fine like a day ago it just didnt pass 3-3500rpms
by the way i have a p06 ecu vtec converted with my l/c nothing major just converted to run the b16 nothing fancy...
Old Mar 17, 2008 | 04:29 PM
z6hatchboy's Avatar
Check for codes anyways, im thinking the map. I've had cars with no CEL, but had codes stored.
Old Mar 17, 2008 | 04:42 PM
so if is the map sensor it would start cuz the my check engine light was on when my car was runnin
Old Mar 18, 2008 | 05:19 PM
so today i checked the cel code and it gave me 20 and 5......
ElswickB22
Oct 9, 2013 07:16 PM
jmh4bb6
Aug 28, 2013 11:15 PM
92redhatch
Mar 18, 2009 05:07 PM
streetracerof06
Sep 2, 2005 07:16 AM
bagged lude
May 3, 2004 12:54 PM
