b16a2 in 92 eg.....HELP!!!!!!!
well here is my problem i did my own wiring for the obd2b distributor to run of my stock harness... now with my wiring harness that i did so my distributor could run off my stock harness actually turn the car on now i do have a lounch control but is at like 4500rpms but when i turned on my b16 i took it for a drive with out connecting my knock sensor hopefully is not a problem.. but it didnt pass 3-3500rpms.. thinking that it could of been my wiring i do go back and double check my wiring so i decide to clean up my little mess with the wiring but i finished my harness and now the car doesnt turn on at all it cranks though
what could this problem be now...
(hopefully i didnt fry ma distributor or coil)
any help would be apreciated
thanks in advance
thanks in advance
Re: b16a2 in 92 eg.....HELP!!!!!!! (tigueremalo)
Any cels? sounds like it could be a map sensor, or something to do with that launch control. If its bogginh though at the rpm you say, your timing probably just off a lot.
Re: b16a2 in 92 eg.....HELP!!!!!!! (z6hatchboy)
but the car ran fine like a day ago it just didnt pass 3-3500rpms
by the way i have a p06 ecu vtec converted with my l/c nothing major just converted to run the b16 nothing fancy...
so if is the map sensor it would start cuz the my check engine light was on when my car was runnin
streetracerof06
09-02-2005 07:16 AM
