Taking off top of air box... Good or bad???
Old Jul 8, 2002 | 03:08 PM
Teg44
Guest
Posts: n/a
Default Taking off top of air box... Good or bad???
Well, I recently took off my AEM CAI from my 2000 GSR, but the only thing was that I missed the sound when the car was in VTEC... So, I took off the top to the airbox, and now I get that loud roar again, the only thing is I don't know if I can mess anything up by doing this... Any feedback regarding this subject will be greatly appreciated.
Thanks.....
Old Jul 8, 2002 | 03:09 PM
Mt3c's Avatar
Default Re: Taking off top of air box... Good or bad??? (Teg44)
bad, you're just sucking hot air now.
Old Jul 8, 2002 | 03:14 PM
o_Rage_o's Avatar
Default Re: Taking off top of air box... Good or bad??? (Mt3c)
bad, the air is not circulating and entring the engine the same way...look up plenum box designs (might need to look up homemade cai posts or info on the net), plus air is hot.
-Rage
Old Jul 8, 2002 | 03:16 PM
poison's Avatar
uhh no.
it's just an intake.....as long as you have the filter hooked up to the intake, doesn't matter.
[Modified by poison, 5:16 PM 7/8/2002]
Old Jul 8, 2002 | 03:29 PM
Arsenal's Avatar
Default Re: Taking off top of air box... Good or bad??? (poison)
Yes. The car runs better with cold air. Thats why a cold air intake costs more than a short ram. So leave it on. try a drop in K&N.
Old Jul 8, 2002 | 03:51 PM
VTECorona's Avatar
It sounded meaner with just the airbox cover off of the airbox than it does with a AEM CAI. Not really meaner actually, just deeper. Hot air though, so its shitty.
Old Jul 8, 2002 | 04:11 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: Taking off top of air box... Good or bad??? (97RedTegGSR)
bad
Old Jul 8, 2002 | 05:44 PM
Arsenal's Avatar
Default Re: Taking off top of air box... Good or bad??? (Jsracingintegra)
Cold air means more oxygen=bigger combustion=more power
Hot air means less oxygen=smaller combustion=less power
Think cold think oxygen. (tm)
Old Jul 8, 2002 | 06:34 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: Taking off top of air box... Good or bad??? (Arsenal)
exactly, also you might think there's more power because its louder but its not.
Old Jul 8, 2002 | 07:16 PM
Lenguaso's Avatar
Unnecessary.
Old Jul 8, 2002 | 07:19 PM
eh-D's Avatar
To answer the original question: no you will not cause damage by running like that.
The stock GSR airbox does not act as a cold air intake becuase it draws air from the engine bay behind the ABS hardware. The ITR box draws air from inside the passenger fender, which is cooler. I doubt you'd see an increase or a decrease in air charge temps with the lid on or off with the GSR setup. You are bypassing the resonator by removing the lid. You might see a 1hp 1-2lb trq drop in the low end by reducing the length of the intake tract and you would see an 1-2hp gain in the top end from the unrestricted airflow, just like a short ram.
Old Jul 8, 2002 | 07:31 PM
01nhbgsr's Avatar
jee i've been running my car without the top cover guess i should put it back on...but is it really that bad??
Old Jul 8, 2002 | 07:34 PM
IC x Prince's Avatar
New User
Default Re: Taking off top of air box... Good or bad??? (01nhbgsr)
Just robbing of HP.
Old Jul 8, 2002 | 07:43 PM
01nhbgsr's Avatar
Default Re: Taking off top of air box... Good or bad??? (UltraGSR)
if i put the top back it would be ok then right?
eh-D's Avatar
It's ok either way.
Old Jul 8, 2002 | 07:44 PM
Chris's Avatar
yes.. it will be fine.. just put it back on.
acecase
Mar 8, 2010 08:37 AM
LewDawg
Jan 22, 2006 10:51 AM
Wolfwood
Jul 27, 2005 04:02 AM
japmarket1
Mar 30, 2005 02:55 PM
