Changing release fork without removing tranny possible??
I got a broken clutch release fork (arm behind the throwout bearing) that needs to be changed out. Can I replace it without taking out the tranny or can I work through that little hole behind the slave cylinder. Or do I HAVE to take the tranny out.
The release fork can be detached from the pivot ball, and maybe removed from the throwout bearing, but I don't know if it will clear the housing or not.
I think this would be VERY difficult if it is possible.
If I have time, I will try it on my spare tranny.
I think the arm snapped because it was not greased up the first time due to it seizing like you said. Im pretty sure I can grease the ball up through the opening.
As for the throw out bearing, its not attached to the arm because its 2 seperate pieces. (bearing and fork)
Thanks for the input guys but anybody else ever try it this way?
spidermancivic
Sep 25, 2004 04:44 PM
