radiator fan
it seems like my fan isn't kicking in when it should. It begins overheating only when I'm sitting still for about 4 or 5 minutes. Once I start moving again it drops drastically to normal temp. Temp sensor maybe?
Any help or info is appreciated...
if your fans not coming on then thats definetely contributing to your over heating, check your fuses, also the fan relay may be bad, check also and make sure none of the wiring is broken or frayed to your fan.
yeah i kinda figured that was the reason why it was overheating
i checked the fuses and the wiring, but skipped over the relay.. i'll check that out tomorrow..
SiMateoAko
Jul 5, 2005 08:11 AM
hybrider
Jul 23, 2002 08:21 AM
