INTEGRA HALF SHAFT AXELS HELP ABS AND NON ABS HELP ME PLEASE!!
Old Mar 17, 2008 | 11:20 AM
cowboys22cardinals22's Avatar
* B A N N E D *
Default INTEGRA HALF SHAFT AXELS HELP ABS AND NON ABS HELP ME PLEASE!!
OKAY I HAVE A PROBLEM...
I HAVE ABS AXELS.... IS THERE A DIFFRENCE BETEWEEN AN ABS AND NON ABS HALF SHAFT?
I HAVE MY PASSANGER SIDE AXEL IN NO PROBLEM... WHEN I PUT THE DRIVER SIDE INTO THE HALF SHAFT IT DONT GO THE WHOLE WAY IN AND CLICK TO STAY... DOES ANYONE HAVE A SOLUTION TO THIS? OR WHAT I CAN DO????
IM UN SURE IF THERES A NON ABS AND A ABS HALF SHAFT... I WAS TOLD THE CLIP ON THE END OF THE AXEL WAS BIGGER AND THATS WHY IT DONT GO IN AND CLICK... SO WHAT WILL HAPPEN IF I REMOVE THIS CLIP/ RING THING?
Old Mar 17, 2008 | 11:26 AM
crazyguy's Avatar
Default Re: INTEGRA HALF SHAFT AXELS HELP ABS AND NON ABS HELP ME PLEASE!! (cowboys22cardinals22)
abs or non abs axles makes no different on a non abs car. and i think all integra half axles are the same
and if u get the right axle.it should fit. u have to push it all the way in.
Old Mar 17, 2008 | 11:28 AM
* B A N N E D *
Default Re: INTEGRA HALF SHAFT AXELS HELP ABS AND NON ABS HELP ME PLEASE!! (crazyguy)
SO WHY ISNT MY AXEL FITTING INTO MY HALF SHAFT
Old Mar 17, 2008 | 11:31 AM
2wheelhunter's Avatar
wiggle and push.. i found it helpful when i put the hub-side into the hub and put the nut on (finger tight) and used the entire hub assembly for mass to push the axle in.
Old Mar 17, 2008 | 11:32 AM
* B A N N E D *
Default Re: INTEGRA HALF SHAFT AXELS HELP ABS AND NON ABS HELP ME PLEASE!! (2wheelhunter)
OKAY I WILL TRY TONIGHT... BUT I HAVE PUT THE AXEL IN 3 TIMES... PUT THE NUT ON THE END HIT IT WITH A HAMMER A COUPLE TIME TO GET IT TO GO IN AND JUST ISNT CLICKING...
Old Mar 17, 2008 | 11:46 AM
marcs1337's Avatar
stop typing in caps, you look retarded...you have to really really push those axles in, you will know when it is in, the last thing you want is for them to fall out while youre driving....it happened to me once and it sucked...check and double check once you have them in to make sure they are in
Old Mar 17, 2008 | 11:52 AM
* B A N N E D *
Default Re: (marcs1337)
i keep my caps locked due to that im at work and i keep them on all day b/c of notes that put on my drawings... sorry...
Old Mar 17, 2008 | 12:18 PM
instrument's Avatar
the side with the half shaft doesn't "seat" itself like the other side
if you're concerned its not fitting properly remove the half shaft, and put the axle into it while its off the car, then insert the half shaft into the transmission.
Old Mar 17, 2008 | 12:21 PM
Jakester9500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcs1337 &raquo;</TD></TR><TR><TD CLASS="quote">stop typing in caps, you look retarded...you have to really really push those axles in, you will know when it is in, the last thing you want is for them to fall out while youre driving....it happened to me once and it sucked...check and double check once you have them in to make sure they are in</TD></TR></TABLE>
sorry man, but typing in caps isn't as retarded as not putting the axle in the whole way
Old Mar 17, 2008 | 12:22 PM
* B A N N E D *
Default Re: (instrument)
yeah i have took the half shaft off the engine and done that but was completely satisfied... so it dont "seat" in there... so your saying that i can easly still pull the axel out?
Old Mar 18, 2008 | 05:25 AM
marcs1337's Avatar
Default Re: (cowboys22cardinals22)
"sorry man, but typing in caps isn't as retarded as not putting the axle in the whole way "
yes that was a retarded move by me, but i was in a crunch for time and i didnt take the time to double check, and i ended up paying for it on the way to work the next morning...
j0keefe21
Feb 14, 2009 08:13 PM
Mr.Death
Apr 11, 2008 11:23 AM
204hatch
Apr 4, 2008 09:11 AM
Mar 17, 2008 05:37 PM
philosofy1
Oct 26, 2005 02:08 PM
