B16A ENGINE SWAP : HELP NEEDED!
Old Mar 17, 2008 | 06:09 AM
civic1.6lsi's Avatar
Default B16A ENGINE SWAP : HELP NEEDED!
hi, i got directed to this site because of the help apparently offered so im new here :D, i currently own a civic coupe 1.6i ls 96-98 engine code : D16Y7! :S i dont like the engine anymore at all so iv secured a loan of 2000 and am HOPEFULLY planning a B16A swap, id like someone to tell me just how much they think il be paying to find the mounts, gearbox etc, what do i actually need other then the engine which i will buy that will include ECU and wiring loom last time i checked. Engine iv seen for about 500 so iv got 1500ish (1700 - 1750 give or take my finances) to spend to get it in....what ya reckon?? :S
im not looking to sell the coupe and just buy a vti either, i want the full package of watching my civic grow :D
thanks for all help given, and abuse thrown of why i was a silly sod and bought a LS in the first place is taken happily lol
Old Mar 17, 2008 | 06:14 AM
Probot's Avatar
Default Re: B16A ENGINE SWAP : HELP NEEDED! (civic1.6lsi)
buying a $500 B16 sounds kind of like a bad idea to me...what kind of shape will the motor be in for that amount of money???
Old Mar 17, 2008 | 06:31 AM
crazyguy's Avatar
$500 for a b16a engine (obd ??), u sure ?
the healthy and come with warranty and complete b16a swap should cost u around $2000~$2500 which comes with ecu,engine and tranny, all sensors and harness.
u will need to get new mounts ,axles, shiftlinkage throttle cable ..etc which will cost u several hundred dollars depends on what u buy
and also u might need exhaust manifold and down pipe cause most of the swap does not come with down pipe and u will need b series cat convertor or have a muffler shop cut, extended and welded your existing d series cat convertor and again there goes another couple hundred dollars. u can go cheap with megan header $180 and muffler shop should costs u around $50
and if u can do the labor by yourself, it will save your around $500~$750. and plus some wear and tear items such as spark plugs and wire,dizzy cap and rotor and a tune up.
so to sum up, u do the math. $2000 is definitely not enough
Old Mar 17, 2008 | 06:42 AM
i forgot to mention im in england sorry, so £500 would more be like $800 to you, comes with ecu and wire loom, roughly 50,000 miles on the clock.
Old Mar 17, 2008 | 06:47 AM
crazyguy's Avatar
Default Re: (civic1.6lsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic1.6lsi &raquo;</TD></TR><TR><TD CLASS="quote">i forgot to mention im in england sorry, so £500 would more be like $800 to you, comes with ecu and wire loom, roughly 50,000 miles on the clock.</TD></TR></TABLE>
ok but b16a tranny will cost u around $600 USD and all the parts i mentioned above.u might be able to do it if u can get the parts cheap and do the labor by yourself. it is not that hard https://honda-tech.com/zerothread/878010
Quazzie
Mar 2, 2017 08:08 AM
v-tec maz
Nov 25, 2004 10:14 AM
unicoder
Oct 13, 2003 09:07 PM
CAT_SPEW
Oct 7, 2003 08:42 AM
The Rob
Apr 3, 2002 11:15 AM
