B16 crank but no start condition...
Ok well Saturday i used the crx to go to work and it ran fine....Sunday the car sat all day. This morning i started it and it started no problem...i let it warm up while i went inside. I come out and its still running but i went to step on the gas and it dies!
Now it just cranks and won't start! My fuel pressure gauge says 0 PSI so i replaced the fuel regulator since i had an old d series one. Still 0psi and crank no start condition....I borrowed a new Main Relay from a friend for now and it does the same thing....crank no start.
Relay clicks fine...
I just used the car Saturday with no problems....it sits for one day and now this...any ideas??
Modified by alscrx at 8:28 AM 3/17/2008
Even though it's rare for a fuel pump to go out on a EF it does happen, don't you think if there is no fuel pressure that you should check the f. pump?
Well today after work i tried to start it and same ****.....it did turn on once and bogged out. The fuel gauge needle never moved off 0psi!
I do have spark at the plugs for sure.....
Do i check for ohms on the fuel clip in the rear?
~UPDATE~
There is a leak from the fuel tank or hose underneath causing the fuel to EVAPORATE
i got to find that leak fast....wonder where its leaking from????????????
i put 1 gallon of gas and she fired right up, My gas needle said it was 1/2 tank before i filled it
AdamJ2
Jul 5, 2008 12:16 PM
blu3g
May 29, 2008 05:18 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
