Swap problems....
Old Mar 16, 2008 | 11:14 PM
djviet2000's Avatar
Default Swap problems....
im wondering which a/c lines do i have to use? i have a 99 civic dx hatch. 98 B18C1 motor with the a/c that came with it. i THINK im running the stock dx lines with the B18 a/c compressor. somebody told me i have to use 99-00 Civic Si lines. i know taking the A/c will make the car lighter but its getting freaking HOT here in texas.
When they did my swap for some reason when i put it in reverse the reverse lights dont light up. my car is orginally automatic. somebody told me i had a connect a wire from my cig lighter to a set of wires near the tranny?
the shop who did my swap REALLY pissed me off. for some odd freaking reason they removed my stock cat and welded on a flex pipe. well since my exhuast is so freaking loud and cop magnet i need to go back to stock stuff. i need a secondary o2 sensor. since i have a B18 will the SOHC 1.6 sensor work? i looked online and they look both the same.
thanx in advance ^_^
Old Mar 19, 2008 | 09:45 PM
djviet2000's Avatar
Default Re: Swap problems.... (djviet2000)
Bump
Old Mar 24, 2008 | 10:02 PM
djviet2000's Avatar
BUMP
Old Mar 24, 2008 | 10:41 PM
AnDy327's Avatar
Takin the AC out dont make your car that much lighter but when you do have it on it cuts power... Id perfer to keep it on and just turn it off before a run... I think both SI and any integra AC lines will work put im only about 70% sure on that one
About your O2 sensor.. As long as its a 4 wire sensor it will work you can buy the universal ones cheaper then the OEM ones but thats without the clip... YOUR CALL.
About your reverse lights... If its automatic you should have a 2 wire clip that powers your breaklights... BUT WHY DO YOU EVEN NEED THOSE?!?! lol..
efekek
Jul 25, 2016 11:32 AM
thatmexican32
Honda Civic (2001 - 2005)
May 10, 2011 05:39 PM
bonestock92si
Jul 21, 2008 07:49 PM
Jesterian
Aug 30, 2005 08:35 PM
RotiEatter
May 22, 2003 12:39 PM
