Replacing auto tranny shift knob
Old Mar 16, 2008 | 09:29 PM
tpot90's Avatar
Default Replacing auto tranny shift ****
I want to get something similar to this.
http://cgi.ebay.com/TITANIUM-A...wItem
Has anyone had an experience with these from ebay? Should the OEM shift **** be easy to take off? And will this one be easy to put on?
Its made of titanium so it should be pretty sturdy.. But once again, I want another opinion.
This one is made of billet, but it doesnt look very nice.
http://cgi.ebay.com/ebaymotors...sting
Any thoughts on which one to get?
I also want to get a boot for the shifter. I think it'd clean up the center console & make it look pretty dam nice. Has anyone done this?
Old Mar 16, 2008 | 11:19 PM
thakidd's Avatar
Default Re: Replacing auto tranny shift **** (tpot90)
i replaced mine wit a advance auto one, very easy to take the stock one off and replace, just unscrew.
Old Mar 17, 2008 | 01:58 AM
Honda_Accord's Avatar
Default Re: Replacing auto tranny shift **** (thakidd)
there are two screws on the oem automatic shift **** on the sides its a Phillips just unscrew and pull off the ****, however watch out for a spring and a white piece that may fly off, as for the boot tons of people do it, matter of fact theres even a write up on another site that you can make ur automatic have a "short shifter" look if u wanted that...
bad thing is, i cant remember where i saw that write up
Old Mar 17, 2008 | 11:12 AM
tpot90's Avatar
Default Re: Replacing auto tranny shift **** (Honda_Accord)
Awesome, If anyone knows where that write up is, let me know! But about the shift *****, I'm kinda sketchy about using one of the ***** that the whole button pushes down in order to take it out of gear & change the gears. Have you guys seen that?
Do you guys know how the mechenism works, seeing that the OEM shift **** has a small button on the SIDE?
Modified by tpot90 at 12:37 PM 3/17/2008
Old Mar 20, 2008 | 01:23 AM
ok i found it, but im pretty sure i cant post it in here so check your pm
Old Mar 20, 2008 | 05:40 AM
TASAuto.com's Avatar
Banned
If you undo the two screws and lift the **** off you will see the actual mechanism
DO NOT LIFT UP THIS PIECE! Your shift assembly will be destroyed because there is a little pin down inside of there.
Many manufacturers sell shift ***** for automatics that will work with this assembly
There are push button style ones
And some types that all you have to do is push down on the entire ****
Old Mar 20, 2008 | 10:04 AM
not-a-stang's Avatar
Default Re: Replacing auto tranny shift **** (TASAuto.com)
Sweet. Thanks TAS. I going to install that carbon fiber shifter **** I had for like 5 years.
Old Mar 20, 2008 | 05:52 PM
tpot90's Avatar
Default Re: Replacing auto tranny shift **** (not-a-stang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thakidd &raquo;</TD></TR><TR><TD CLASS="quote">i replaced mine wit a advance auto one, very easy to take the stock one off and replace, just unscrew.</TD></TR></TABLE>
Ok please answer this: Where can i get the shift boot? Will the MT boot fit the automatic? Where can i get one that fits the AT? Is there? Or do i just need to use a MT boot?
Old Mar 21, 2008 | 04:25 AM
Banned
I will pm with more info
Old Mar 21, 2008 | 06:05 PM
96_Accord_lx's Avatar
Host i would like to get sent everything you got sent please!
Old Mar 21, 2008 | 10:44 PM
361 accord's Avatar
thats what i was thinkin oif doin,
put an ITR shift boot over my auto shifter soince ive got lights on the dash anyways...
Old Mar 22, 2008 | 07:50 AM
Ricky616's Avatar
Default Re: (96_Accord_lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96_Accord_lx &raquo;</TD></TR><TR><TD CLASS="quote">Host i would like to get sent everything you got sent please!
x2 can someone send me the info i been thinking of doing this as well. What shift **** would you guys recommend? i have a 97 se accord.
Old Mar 23, 2008 | 12:58 PM
tpot90's Avatar
Default Re: (Ricky616)
Once again, no one has answered the only question ive asked. Will the MT shift boot fit the AT?
Old Mar 23, 2008 | 05:56 PM
361 accord's Avatar
Default Re: (tpot90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 &raquo;</TD></TR><TR><TD CLASS="quote">Once again, no one has answered the only question ive asked. Will the MT shift boot fit the AT?</TD></TR></TABLE>
just try it!
Old Mar 24, 2008 | 04:06 AM
Banned
Default Re: (361 accord)
Yes the MT boot will fit the automatic but you must remove the AT shift plate
Old Mar 24, 2008 | 04:22 AM
Banned
Default Re: (TASAuto.com)
if you want more info on this please pm me
Old Mar 24, 2008 | 10:22 AM
dohctor_B's Avatar
I did not have to remove my automatic shift plate. You just need to disassemble your armrest and the radio surround to access the shifter plate. I used a manual shift boot right over the shifter plate using string and zip ties to keep it down. I can go through all my gears without it coming out. Here is the setup for the OP:
Shifter - Ebay special, you push down on the whole shifter (spray painted black)
Shift boot - 92-95 civic EG manual (MT) shift boot
Accesories - Zip ties and string
Old Mar 24, 2008 | 10:56 AM
Banned
Default Re: (dohctor_B)
or if you want to have it screw into the console you can get the OEM Accord boot and screws
Old Mar 24, 2008 | 11:12 AM
tpot90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohctor_B &raquo;</TD></TR><TR><TD CLASS="quote">I did not have to remove my automatic shift plate. You just need to disassemble your armrest and the radio surround to access the shifter plate. I used a manual shift boot right over the shifter plate using string and zip ties to keep it down. I can go through all my gears without it coming out. Here is the setup for the OP:
Size:  58.9 KB</TD></TR></TABLE>
How is that **** working out for you? I want one like that, but im hesitant of getting it from ebay. I want the Razo one. But if you are having a good experience with it, i might just get one from ebay.
Old Mar 24, 2008 | 11:57 AM
tpot90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TASAuto.com &raquo;</TD></TR><TR><TD CLASS="quote">or if you want to have it screw into the console you can get the OEM Accord boot and screws</TD></TR></TABLE>
TASAuto, is the OEM boot that you sell on your website very similar to Dohctor_B's shift boot? Is it similar to the 94-97 accord shift boot? There is no pic to enlarge on the 6th gens. If it is exactly like the 5th gen one shown on your site, i'll purchase it.
What other shift boot from Honda will fit my accord? I want one that screws into the stock holes.
Also, what are the dimensions of the Razo shift **** that you sell with the shift boot? How tall is it?
Modified by tpot90 at 1:16 PM 3/24/2008
Old Mar 24, 2008 | 12:28 PM
Banned
I was try to keep these posts about general info and not an ad for our company.
The Razo **** is about 4 inches tall- Here is a comparison
That should give you a good idea of what size it is. We use an oem shift boot and remove the collar so that the boot will match the console and the ****. We provide oem mounting screws so that the boot bolts up to the factory console. Razo makes a quality product and I had this **** in my personal car for more than 4 years and never had a problem.
The 4th, 5th and 6th gen kits all use different shift boots. They are all the year specific oem boots so that they will be a direct bolt-in with no modification. For the 98-02 click on the enlarged image and you can see the difference in the mounting brackets between the generations.
Old Mar 24, 2008 | 01:15 PM
dohctor_B's Avatar
How is that **** working out for you? I want one like that, but im hesitant of getting it from ebay. I want the Razo one. But if you are having a good experience with it, i might just get one from ebay. </TD></TR></TABLE>
The **** works fine. It is a simple design with a spring inside of it and a base to allow you to push down on the whole assembly. I can't imagine it breaking, unless by an act of god the spring somehow breaks. Anyway, my job I did was custom since I used a EG shift boot. I discarded the bracket and just used good ol' zip ties and some string to keep it from coming out.
Trust me, this mod is not really a difficult thing to do, but there are two ways to do it. Either you do what I did and just buy some cheap shift **** and any shift boot you've got lying around (I had a EG shift boot in my garage) and take apart the plastics around the shifter and just work some magic. Or you can buy the Razo shift **** and a OEM accord boot so that you can screw it in using factory mounts. You can mix and match whatever combination you want: It's up to you and depends on how much you want to spend. It's suprisingly simple and cheap (only $10 for me). good luck
Old Mar 24, 2008 | 01:31 PM
Installed my shift ****, gonna hit up the wrecking yard for the manual shifter boot.
Old Mar 24, 2008 | 03:12 PM
Someone explain a shift plate to me??? If i just put the boot under the plastic piece covering the part that has the letters for my gears will it stay there or do i need to bolt it down or something?
Old Mar 25, 2008 | 03:19 AM
Banned
The shift cover plate is the piece with the letter for your gears on it. You can see in the above stock picture that there isn't exactly a gap inbetween the plate and the black console. You might be able to squeeze a boot in there but it is easy enough to undo the 4 screws holding on the plate.
