96 Accord won't start after sitting up for 4 years.
Old Mar 16, 2008 | 07:28 PM
Bayourat's Avatar
Default 96 Accord won't start after sitting up for 4 years.
I have a 96 Accord that sat up for 4 years. I replaced the battery. Changed the oil and gas. It's turning over good. Spark Plugs are getting a Spark. The Fuel is getting to the Fuel Rail and the Fuel Pump is working. It seems like no fuel is getting into the cylinders. Any suggestions on further troubleshooting are greatly appreciated.
Thanks,
whitney@bayourat.com
Old Mar 17, 2008 | 03:38 AM
ohgood's Avatar
Default Re: 96 Accord won't start after sitting up for 4 years. (Bayourat)
you already said it had spark, so let's assume your injectors are clogged with varnish from the old gas, or the signals isn't making it to them to 'fire' the gas in.
i'd pull the injectors and have a shop do a cleaning, or verify they work. if they do, i'd suspect they aren't getting a signal.
Old Mar 17, 2008 | 06:45 AM
Bayourat's Avatar
Default Re: 96 Accord won't start after sitting up for 4 years. (ohgood)
How can I check to see if an injector is firing?
Old Mar 17, 2008 | 11:56 AM
Patman's Avatar
They click.
Old Mar 17, 2008 | 04:28 PM
Bayourat's Avatar
Default Re: (Patman)
If I use a test light on the injector plug will this tell me if the injectors are firing?
onlymeplus3
Sep 30, 2017 07:09 PM
littlered06
Dec 3, 2010 03:58 PM
nicnak
Aug 4, 2010 05:25 PM
mutt
Jul 14, 2003 01:34 PM
