Manual Tensioner bracket question
when converting to a manual tensioner posts say the L bracket where the auto tensioner used to be will make the tensioner to tight and you cant put the belt on, can you just not use the bracket or will i run into problems keeping the timing belt tight ?
Dont use the bracket but buy shorter bolts to go in the oil pump/block where the tensioner or bracket would bolt to. As long as u follow the instructions to a T, it should work great.
I've seen this talked about, but didn't read much in to it...what's the deal about swapping a tensioner? I just swapped a jdm h22a into my '93 Prelude si and never did this. Is this necessary?
2ndgenteg-md
Apr 11, 2008 05:54 PM
