radiator leak coming from oil pan...
Old Mar 16, 2008 | 06:08 PM
dwuknoit's Avatar
Default radiator leak coming from oil pan...
i dont kno how to fix this problem and was wonderin does anyone kno how to fix it... what had happen was i putted some new coolage in my radiator in my da and all of a sudden there was a leak... i jack my car up to see where it as coming from and it was leakin for the edge of the oil pan... it is wired i never seen this happen before and was wonderin does anyone kno how to fix it... how did water in up leakin from there...
Old Mar 16, 2008 | 06:11 PM
ls19integra95's Avatar
Default Re: radiator leak coming from oil pan... (dwuknoit)
coolage? you mean coolant? but any way, depends where the coolants dripping from, front or back... in the back the engine bay you have your radiator hoses, thermostat housing, water pump, heater core hoses, iacv with two small collent lines, and in the front you have the bleeder valve, hoses... just check above where the coolant is on you oil pan, most likely one of your hoses are beginning to crack or is loose and leaking.
Old Mar 16, 2008 | 06:20 PM
dwuknoit's Avatar
Default Re: radiator leak coming from oil pan... (ls19integra95)
its coming out of the crack where the oil pan is connected to the engine.... that the thing... what can it be...
Old Mar 16, 2008 | 06:22 PM
there is no coolant lines or anything down there, its coming from some place higher where its leaking and just running down your block or trans and dripping from the bottom... just double check around all the hoses and see if its wet any where else, try having the car running and warmed up while looking also from the top to see if any the hoses are leaking slightly
Old Mar 16, 2008 | 06:26 PM
dwuknoit's Avatar
no im foreals its coming from the cracks... there isnt a drip coming down from anywhere... i also checked the oil on the oil stick and it looked water out a little...
Old Mar 16, 2008 | 07:10 PM
there is no coolant hose there period, i know, i have ripped my teg motor apart from a bare block and rebuilt it before... if you have water in your oil then you blew your head gasket and its running down the side your trans and mixing in your oil.
Chads7
10
Sep 25, 2010 11:22 AM
profesional-hobo
Apr 17, 2009 07:28 AM
Kafelatte
Jan 10, 2007 10:30 AM
92hybridAccord
Nov 26, 2003 04:05 AM
krazn
Nov 30, 2002 03:13 PM
