need to get this thing on the road~!~!~!~!
for 4th gens, ok hopefully i dont sound to dumb sry if i do, but ok first...i dont have a bumper reinforcer or bumper support what ever you want to call it, i know its dumb i dont have one but i jsut need to know if anyone else is running there prelude without theres and if so how are you keeping it on?cause i jsut need to make this work for a while. please help.
Modified by bubxba at 6:59 PM 3/17/2008
can you upload a pic? front or rear? without support you risk catastrophic damage to your vehicle if you are in even a minor accident.... search an online junkyard perhaps?
the front, and i would buy one, im going to buy one i jsut have no money now and need transportation, so untill then i need something even if it means taking the risk of major damage, so if anyone can help thats running there 4th gen without it lt me know how your keeping it on.
Just drive around with no bumper for now. Not sure if its Illegal but screw it. Which bumper support are you missing, the sterafoam part? Or what, pics would really help you out more here
1. install the bumper on place and use 2 big tapping screws to fasten the corner fender to the corner of the bumper.
2. use a floor jack (or something else) to support the middle of the bumper up so its flush with the headlights and hood
3. buy some 3/4" wide flat stock steel at a hardware store. get some bolts and nuts too
4. using a vice and big pliers bend and cut 2 pieces to stretch from your radiator support to your bumper, then use the bolts and nuts to fasten them all together. (the black metal pieces in the pictures)
NOTE: i still highly recommend getting a bumper beam, and soon! this is not a safe solution, as you can tell from my pics i am still using a bumper beam, i had to do this because it is a body kit and the factory upper part fit poorly and needed more support, so i used steel instead of plastic to make it fit properly.
good luck
close-up
back shot
good luck
close-up
back shot
ahh thnaks alot man, im gettin the support soon jsut didnt want to ride around with no bumper.but this looks greatthanks.
crip
Aug 17, 2010 04:42 PM
