H22 EG axle ???(searched)
Old Mar 16, 2008 | 05:15 PM
Tampa Native's Avatar
Default H22 EG axle ???(searched)
OK i have a h22 eg im changing trannys.I'm throwing in a m2f4 w/quaife.I'm using 90-93 accord mid shaft so i know i need 90-93 teg axles with accord/prelude inners.My question is how do you remove/replace the inner joint i cant find any info covering this.Is it difficult to do,dont think it is but never done it only replaced the whole axles.Any info will be a great help.Also i was wondering if a camber kit would help with axle alignment?I dont have binding but im not that low just thinking a camber kit might help.Thanks HT!
Old Mar 17, 2008 | 06:18 AM
Mikey3000's Avatar
Default Re: H22 EG axle ???(searched) (Tampa Native)
you don't need prelude inners. all you need is a stock 90-93 integra axle.
Old Mar 17, 2008 | 07:15 AM
Default Re: H22 EG axle ???(searched) (Mikey3000)
Thanks.I always thought it would'nt lock in the tranny with the stock inner.Can any body else confirm this for me.Thanks for the help!
Old Mar 17, 2008 | 05:51 PM
PwRLiMeH22's Avatar
Yeah.
Old Mar 17, 2008 | 06:22 PM
Default Re: H22 EG axle ???(searched) (PwRLiMeH22)
Yeah?Yes to teggy inner fitting or yes the teggy inner will not lock in? Im confused trying to gather up all parts i need before i swap trannys this weekend.Also any thoughts on the camber kit?Im not that low but i do get camber wear,could this also help with axle alignment?Thanks again HT!
Old Mar 18, 2008 | 03:08 PM
Bump for not wantig axle issues!Where are the H22eg guys i need confirmation.I thought this is the right place to ask.TIA.
Old Mar 19, 2008 | 08:06 PM
H22Stew's Avatar
90-93 integra axles are what you need, along with an accord (or prelude ??)intermediate shaft. The only issue is on teh passenger side inboard joint will have trouble locking in, and is prone to popping out unless you open up the snapring and really force it to lock into place. A better solution is to use the inboard joint off a 90ish accord (or prelude ??) and graft it to the Teg axle on that side. With this setup it will lock into the tranny as it should. This is what I run and it works fine so far.
Old Mar 19, 2008 | 08:21 PM
Default Re: H22 EG axle ???(searched) (H22Stew)
Yeah i was doing more reading and found out about opening up the snap ring.Basically i will see what set up i have when i take it out and copy that.Since i have no issue now i should be good.Also what is invovled in "grafting"the inner to joint to the axle?Thanks for the help!
Old Mar 19, 2008 | 09:56 PM
superfast666's Avatar
its not that hard to build the axle for the passenger side take a 90-93 teg axles remove inner and replace with prelude inner very easy to do have made these many times
Old Mar 19, 2008 | 10:16 PM
Default Re: H22 EG axle ???(searched) (superfast666)
Cool i guess i will be doin it this weekend.Thanks for all the help its much appriecated.I wait to get this done.
jdmegh
May 25, 2007 07:21 AM
JDM_COUPE
Jan 2, 2006 07:11 AM
T"u"Rtle
Nov 5, 2005 06:54 AM
hondaguyexsi
Jun 23, 2005 08:01 AM
doobiesack23
11
Jan 24, 2005 07:59 AM
