Help! My speedometer stays on 0.
Old Mar 16, 2008 | 03:32 PM
jdmdc22's Avatar
Default Help! My speedometer stays on 0.
My speedometer does not move when im driving. The miles dont change either. the rpm moves but not the speed, it just started happening....what could it be??? Thanks
Old Mar 16, 2008 | 03:52 PM
crazyguy's Avatar
Default Re: Help! My speedometer stays on 0. (jdmdc22)
check your VSS sensor. vehicle speed sensor.located on the tranny
r3vmixman's Avatar
Simple fix. Just replace your speed sensor located on your tranny. Should be 1 10mm bolt.
Old Mar 16, 2008 | 03:53 PM
integ401's Avatar
Default Re: Help! My speedometer stays on 0. (r3vmixman)
Make sure it's the problem first. See if your getting any voltage from it.
Old Mar 16, 2008 | 04:00 PM
GserpleaSR's Avatar
Check fuse's first!
Old Mar 16, 2008 | 04:03 PM
Dogginator's Avatar
Daisy... Daisy...
What chassis? DA, DC, etc.? Also what year.
Old Mar 16, 2008 | 04:42 PM
jdmdc22's Avatar
Default Re: Help! My speedometer stays on 0. (Dogginator)
96 dc2
Old Mar 16, 2008 | 05:02 PM
Fern413's Avatar
check the wiring that plugs into your vss sensor
Old Mar 17, 2008 | 08:46 AM
jdmdc22's Avatar
Default Re: Help! My speedometer stays on 0. (Fern413)
bump
Old Mar 19, 2008 | 10:16 AM
jdmdc22's Avatar
Default Re: (GserpleaSR)
bump
Old Mar 19, 2008 | 10:22 AM
crazyguy's Avatar
Default Re: (jdmdc22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc22 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
we have already given u the answer, have you check VSS yet ?
Old Mar 19, 2008 | 10:23 AM
Dogginator's Avatar
Daisy... Daisy...
Het a Helm manual for the car and troubleshoot the VSS. You will need a multimeter capable of capturing signal pulses. Several things could be wrong:
1) the gear for the VSS is damaged
2) The VSS is damaged
3) A wiring issue.
HighCardAce
Nov 5, 2009 01:42 PM
hbhonda
Oct 20, 2009 06:34 PM
Cassell08
Mar 11, 2007 01:04 PM
96 EX
13
Jan 3, 2007 12:22 PM
Gouki133
Dec 13, 2006 10:27 AM
