Going to dyno tune..
Old Mar 16, 2008 | 03:16 PM
SilverWarrior's Avatar
Default Going to dyno tune..
Going to dyno tune, and its 175/hr .. how long should I pay them to tune my car for? There is a flat rate that they tune until its right but it cost more... but I don't want to pay unnecessary money if they can tune it within an hour.
Old Mar 16, 2008 | 07:42 PM
Default Re: Going to dyno tune.. (SilverWarrior)
no one can help =0
Old Mar 16, 2008 | 08:16 PM
this section is dead
Old Mar 16, 2008 | 08:32 PM
civicstar's Avatar
first of all, what motor, what mods, turbo or NA or Nitrous
What engine management are you using
usually it should take less then 1 hour normally for NA
Old Mar 16, 2008 | 08:38 PM
serio_ENDLESS's Avatar
yeah we need a little detail so we can actually estimate how long
Old Mar 16, 2008 | 09:11 PM
Default Re: Going to dyno tune.. (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">first of all, what motor, what mods, turbo or NA or Nitrous
usually it should take less then 1 hour normally for NA</TD></TR></TABLE>
for a LsV(NA) , stg2 cams on p28 ecu crome.
Old Mar 16, 2008 | 10:17 PM
civicstar's Avatar
a good tuner will do it about 1 hr or less
Old Mar 17, 2008 | 01:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">a good tuner will do it about 1 hr or less</TD></TR></TABLE>
kk
anyone else agree that I should only pay for an hour tune .
Old Mar 17, 2008 | 05:24 AM
Padawan's Avatar
Darth ModerVader
A good tuner will know that you can't achieve a proper, full tune in 1 hour.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverWarrior &raquo;</TD></TR><TR><TD CLASS="quote">
for a LsV(NA) , stg2 cams on p28 ecu crome.</TD></TR></TABLE>
Expect at least a few hours if your tuner is going to do a thorough job. Many tuners will charge a flat rate for an ECU tune, which can be advantageous for many people depending upon your setup.
Old Mar 17, 2008 | 01:16 PM
Junior Wock's Avatar
Default Re: Going to dyno tune.. (Padawan)
How many pulls, 10 pull is a lot watch out.
Old Mar 17, 2008 | 01:29 PM
ickyhonda's Avatar
Default Re: Going to dyno tune.. (Junior Wock)
Is the tunner familiar with CROME? How much for a full tune (tune untill it is right)? Is it an inertia dyno, load dyno???
Old Mar 17, 2008 | 07:45 PM
Garage 808 Hatch's Avatar
Default Re: Going to dyno tune.. (ickyhonda)
it all depends on what they tune, if thet just do air/fuel and ignition, then a couple hours will suffice, but if you have them do cam tuning also, it can rack up some more time, as everytime you move the intake cam, you must retime the motor. some start timing from when they start strapping down, others start when they start the first pull, it all depends.
Old Mar 17, 2008 | 11:25 PM
Default Re: Going to dyno tune.. (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ickyhonda &raquo;</TD></TR><TR><TD CLASS="quote">Is the tunner familiar with CROME? How much for a full tune (tune untill it is right)? Is it an inertia dyno, load dyno???</TD></TR></TABLE>
Yea the tuner is familiar. A full tune would be $375 and its a Dynapack which uses hydraulic loading to test and measure the output of an engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">it all depends on what they tune, if thet just do air/fuel and ignition, then a couple hours will suffice, but if you have them do cam tuning also, it can rack up some more time, as everytime you move the intake cam, you must retime the motor. some start timing from when they start strapping down, others start when they start the first pull, it all depends.</TD></TR></TABLE>
The cam gears are going to be set to 0 after the head rebuild.
Old Mar 18, 2008 | 09:36 AM
why set at 0?? to begin with yes, but you can get some more hp usually by dialing out some overlap.
Old Mar 18, 2008 | 10:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">why set at 0?? to begin with yes, but you can get some more hp usually by dialing out some overlap.</TD></TR></TABLE>
because it is running really rich ?
Old Mar 19, 2008 | 10:05 AM
ya, start out at 0, and when he gets the A/F right and the timing, start advancing the intake cam 1* at a time, reset the base timing, and make a pull.
umair
16
Feb 21, 2009 05:40 PM
DC4R27
Mar 1, 2007 09:35 AM
vladd
Feb 24, 2007 06:23 PM
Integra414vteC
Jan 11, 2007 11:59 AM
pootie.teng
Jan 3, 2007 10:40 AM
