Throttle Cable Bracket? HELP!!!
Old Mar 16, 2008 | 02:37 PM
vtec93accord's Avatar
Default Throttle Cable Bracket? HELP!!!
Ok, once again, i got a GSR that im swapping into my EF hatch. I was told i needed a B16 or Type R throttle cable bracket. Im running the Skunk 2 Intake manifold and the bracket that i have(as seen in the pic below) isnt going to work. If i leave it as is, it wont clear the PCV hose that goes to the intake. Also if i flip it over it wont clear the intake air temp sensor either, what should i do?
Can anybody help me out with the throttle cable bracket issue im having?
Old Mar 16, 2008 | 03:01 PM
biggee's Avatar
uh, get another bracket.
Go to the salvage yard and pull a bunch off of different engines and see which one fits the best or modify one to fit.
Old Mar 16, 2008 | 03:04 PM
I know there is one that fits fine, i just need to know which one, maybe this is it and it just needs to be flipped over and bent upwards so it clears the air intake temp sensor.
Old Mar 16, 2008 | 03:17 PM
biggee's Avatar
when I swapped on my Y8 manifold to my Z6 I had to use a different bracket and I modified it to work properly. Keep trying, you will find one that works.
Modified by biggee at 8:34 PM 3/16/2008
Old Mar 16, 2008 | 06:06 PM
I guess ill try flipping it over and bending it so that it will clear the air intake temp sensor and see how that works. Unless anybody has any other options?
element1791
Dec 23, 2014 05:35 PM
eg-ed
Aug 26, 2006 04:02 AM
JDM00SI
Jan 22, 2006 02:06 PM
DSRxCandyh2bEG
Mar 29, 2004 06:39 PM
Garcia-Racing
Feb 27, 2004 05:02 AM
